The big oak hoard score
Discussion in 'The Wood Pile' started by bigfrank, Apr 1, 2019.
  1. bigfrank
    bigfrank
    NorCal
    Got a friend that may come down and help. Mini excavator might work, but would still need to be bucked down to firewood lengths. I think I have time. He is only worried about a couple of piles that will be in his way in three weeks. I should be able to get thme whipped aout as they are right on the side of the road. The rest I can cut when I want to.
    chipper1, Chaz, Stlshrk and 6 others like this.
  2. bigfrank
    bigfrank
    NorCal
    Most are bigger than 24". I don't think the stem is coming down, at least he didn't say it was. I showed it to my wood cutting buddy and said if we could get the stem and get it on the ground, it would need to be sawn into lumber. It would be a saste to cut it up into firewood. His response was "I'll go buy a mill big enough to do it!"
  3. Rope
    Rope
    Alaska
    If you go the mini escavator route, reserve for a weekend. Have all the rounds bucked prior to equipment arrival, then go beast mode. Now is the time to see who has a big ported saw for sale. Rental place may have a big saw also like 880.
  4. amateur cutter
    Mini Ex if you can. Cut it to length & noodling doesn't go too badly. Pie cut it & it'll split apart fairly well. I've taken apart many 3 to 5' trees this way. it's work, but if you need the wood it can be done. 75cc saw is bare minimum there, but you can get it done. Keep the bar tip down & power head up to clear the noodles. I switch saws every few of those real big ones to keep the heat down in the saws.
  5. Karvinkanuck
    Karvinkanuck
    I have a small tractor as well, I have split some large material using forks , scoop under neath and place on vertical splitter
  6. bigfrank
    bigfrank
    NorCal
    I have a couple of 75cc saws, so I could go that route.
  7. bigfrank
    bigfrank
    NorCal
    Hmmm, might have to look into some forks. That might work good for moving them around.
  8. jrider
    jrider
    The lift on my tw6 is only rated for 500 pounds those monsters are WAY more than that!
  9. Canadian border VT
    In case people don't know a tw6 is commercial machine..
    Other though still bolt in it drag with FEL..
  10. Karvinkanuck
    Karvinkanuck
    QUICK ATTACH FOR JOHN DEERE ABOUT 400 BUCKS , WELL WORTH THE PRODUCTION
  11. bigfrank
    bigfrank
    NorCal
    Ran down there for a better look and to get a game plan. The two piles that need to go first are right on the road and on level ground. Cutting shouldn't be to big of a deal, but rolling to get the bottom to the top for finish cut will be a chore. Quite a bit of it is 34" as you can see in the pics from today. The smaller stuff won't be a problem. I have a 4' peavey coming tomorrow from TSC that should help. Supposed to have a buddy with me also on Thursday. Might get him splitting while I buck. If I can roll the big stuff, I can move the splitter to the big bucked pieces and chunk them out vertically. Never the less, a lot of work, but I think it will be worth it. More pics to come when I get started.
  12. Midwinter
    Firewood is work, but it will be well worth your labor.
  13. buZZsaw BRAD
    good luck with them bigfrank ! Those big uns can be a b%$#h to move but make lots of splits. :axe: Work safe and keep us updated.
  14. Rope
    Rope
    Alaska
    Looks like your getting close, did you rent any equipment? Those pic, makes me want to call in sick and come help.
  15. bigfrank
    bigfrank
    NorCal
    No, I didn't. I'm going to do what I can without rentals as best as I can. Then when I get to a point where I can't do much more, I'll get that part figured out. There is a lot more then I thought I could get without too much more tools. At least I think. We shall see...
  16. bigfrank
    bigfrank
    NorCal
    Well I hit the hoard for the first time today. Got some bucked up and split, and some just busted down small enough to load by hand. Will finish splitting that part at home. Headed down tomorrow to load up what we got done today, and maybe get some more bucked down.. I'm beat!!!
    Here are a few photos...
  17. billb3
    You usually don't have to get a wedge driven in that far with red oak.
    I'm not saying it's easy but you can move right along.
    I've used a short handle maul to tap with.
    I think it's easier than swinging an axe.
  18. JoeinO
    JoeinO
    NEO
    You are making this FHC member proud bigfrank. Only thing better than git er done is got er done and it looks like you are making it happen.
  19. T.Jeff Veal
    The rounds on the trailer are 20" long and average 950# each
    362 with 25" bar
    These pipe don't roll, but the wood slides on them fairly easy. 1 1/2" handrail pipe welded to angle iron.
    IMG_20180720_132925695.jpg Do you have a FEL on your tractor? There are several ways to handle big rounds. We have 2 hooks welded on our bucket with short chain and log tongs. I have set huge rounds on foot of splitter with tractor. Roll the rounds with the Peavy.
  20. buZZsaw BRAD
    Great work bigfrank !:thumbs: Is it close to home or did you have to travel far with your equipment?
