The adventures of a new ope service writer
Discussion in 'Chainsaws and Power Equipment' started by bocefus78, Apr 5, 2018.
  1. Horkn
    I think it was Emeril Lagasse.
    Just getting back at the tree service for stealing his catch phrase.
  2. Horkn
    Neither of your mowing apparatus have those small hydraulic pumps that seen to burn out more often than they should on zero turns.
  3. bocefus78
    bocefus78
    Indiana
    Buy a better machine with bigger and better pumps. I know a guy if you need one :) Did I mention I am good at spending other peoples money?
    papadave, wildwest, basod and 11 others like this.
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
    You're gonna make some lucky guy really happy someday.
    basod, RCBS, eatonpcat and 10 others like this.
  5. Horkn
    My company sells pumps and anything hydraulic related. I've got it covered if I were to ever get a zero turn. I don't see that happening as I've got a great garden tractor. That and those zero turns have a design flaw that requires both hands on the controls at all times. That makes drinking beer while mowing difficult.;)
    Dancan, wildwest, basod and 11 others like this.
  6. Eric VW
    Not on an old Scag 3 wheel....:yes:
    wildwest, basod, RCBS and 4 others like this.
  7. brenndatomu
    A seasoned operator can run one handed on the straights...and gradual turns...:whistle:
    wildwest, basod, RCBS and 11 others like this.
  8. Eric VW
    Oh boy.....:wacky:
  9. Horkn
    Beer helmet. But drinking beer from a straw it's wrong.
    Zero turns are good at what they do, but are single use tools. IE, they only mow. The tractor can mow, blow snow, run pto implements, haul firewood, etc.
    papadave, wildwest, basod and 10 others like this.
  10. Eric VW
    The 3 wheel Scag I rode back in the early 90’s was useful for all but snow blowing....heck, we used it to pull out small (3-5” diameter) pines!:yes:
    wildwest, basod, Hammy and 4 others like this.
  11. leoht
    leoht
    Victoria. Australia. Earth.
    My Walker zero turn is steered single handed.
    wildwest, basod, RCBS and 7 others like this.
  12. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    Problem solved!
    'Merica Mullet Guzzler Hat
  13. Backwoods Savage
    But methinks zero turns have become a status symbol.
    MasterMech, wildwest, basod and 6 others like this.
  14. eatonpcat
    So true, I was riding around on Sunday and it seemed like everyone cutting was on a zero turn!!
    wildwest, basod, Eric VW and 4 others like this.
  15. MikeInMa
    I cut with zero turn... when I walk behind my mower and get to the end of the row, I spin the mower around and walk it back from where I came.
    papadave, Dancan, wildwest and 17 others like this.
  16. RCBS
    RCBS
    Over here
    This is quite true. I used to be on the sub-compact only team...then I got a ZT. I did however keep the tractor when I got the ZT. The tractor has been indispensable for a multitude of chores, and still is. The zero turn hands the tractor it's azz when it comes to mowing in terms of speed and quality of cut.
    I think I got it right. Bought a ten year old, one owner machine of the industrial variety with 800 hours. Fixed a few small things and now I have a beast of a mower that should last me a long time...that was the plan at the time of purchase anyways...we'll see.
    papadave, eatonpcat, Horkn and 9 others like this.
  17. brenndatomu
    How do you like those ag tires on there? Do they tear the grass up when you turn?
  18. Horkn
    True, zero turns are fast at mowing. I don't think the quality of the cut is better though.
  19. RCBS
    RCBS
    Over here
    At first, yes. This is my first ZT, so there was a learning curve. My buddy who runs turfs tells me that he does some damage with his Exmark sometimes. I think it is inevitable with the ZTs. I don't mind a little damage. The benefits of the AG tires for sure outweighs the negatives. I just almost got sucked into a ditch on Tuesday while mowing. A generous amount of stick kept me moving and the tires pulled me right up out of it. I will have to take a picture or video of one of the hills I mow with it. Holds very well on side sloping as well. It will try to wheelie usually before spinning out. I do have to credit the machine a little...it's just a heavy beast and weight is great for traction. Honestly, my front casters tear up just as much turf as the rear tires do if the ground is moist.
    I can only compare to the deck on the JD2305. It's a 62" "Edge" deck. Stamped, about 4" of depth. It does pretty good, but the ZT has higher blade speeds which in my case anyways, gives a better cut via more lift. The deck on my ZT is 6" deep and handles the thick stuff much better. Much less clumping of clippings also. Not trying to say that any ZT will outcut any riding mower, but in my case it holds true.
  20. TurboDiesel
    Just found this on youtube. Really good idea!!
    Check it out
    Eric VW, basod, RCBS and 5 others like this.
