Testing acid concentration any chemists to set me straight ?
Discussion in 'Everything Else (off topic)' started by Screwloose, Jan 27, 2022.
  1. Screwloose
    Screwloose
    So I use glacial acetic acid to pickle hot rolled steel to remove mill scale. When I first mixed it up I did 25%. Since then I have guessed at adding water and more acid leaving me at no clue as to the strength.
    Do I want PH test strips ?
    Am I over thinking this as in the stronger the better ?
    I'm sure someone here can send me in the right direction.
    Thanks for any help
    Keith
  2. stuckinthemuck
    stuckinthemuck
  3. Screwloose
    Screwloose
    When I first did 25% it worked fine and did the job. But with evaporation and I'm sure weakening the acid plus me adding acid it's now unknown what it is. I was hoping to make a accurate 25% mix and use it as a "standard" of comparison. But I'm not sure what to get for use in comparing the two. Also it's contaminated with mill scale if that matters. If I can get 25% strength +- say 5% I think that would work.
  4. stuckinthemuck
    stuckinthemuck
    So I think you might be able to determine the concentration if you had a hydrometer similar to what they use to determine the sugar concentration in maple sap. This website talks about how to calculate the density based on the mixture of concentrated acetic acid vs water. If you know what your density is to start off with, you can add acid or water to get back to that density. More than one way to skin a cat.
    https://www.quora.com/Suppose-a-sol...ter-What-pH-will-the-solution-have-at?share=1
  5. stuckinthemuck
    stuckinthemuck
  6. Screwloose
    Screwloose
    Ouch, that's like being in school.
  7. Screwloose
    Screwloose
    I wonder if the one for a lead acid battery would work. I have those I'll give it a try can't hurt.
    Thank you for your time and help it's much appreciated!!
  8. stuckinthemuck
    stuckinthemuck
    No. I actually took the time to read it.. if I was in school, I’d be staring at the legs of the hot girl sitting next to me and would have learned nothing while sitting in class…
    so if concentrated acetic acid has a specific gravity of 1.049 and water is 1, then your 25% solution should be 1.01225…. If your specific gravity ends up at 1.00612, you are now at a 12% solution and would have to add an amount of acetic acid equal to about 17% of the total mass to get back to 25%…. So say you start with 100 kg of solution of which 25 kg is acetic acid.. at the end of the process, you still have 100 kg of solution (some insoluble iron compound will have precipitated out) with 12 kg of acetic acid…. So if you add 17kg, you are now at 117 kg of solution with 29 kg (or 25% being acetic acid…. Measure with the hydrometer, math with a calculator..,
  9. stuckinthemuck
    stuckinthemuck
    Good luck and you’re welcome..
  10. Screwloose
    Screwloose
    It makes more sense coming from you. Somehow less intimidating.
  11. TurboDiesel
    We've pickled SS pipe and cleaned up SS welds but always used the acid straight out of the jug.
    I know. I'm not much help.:emb:
    Just moral support.:handshake:
  12. Horkn
  13. Screwloose
    Screwloose
  14. Screwloose
    Screwloose
    What acid ? I know nitric passivates the sanitary tube welds I do.
  15. TurboDiesel
    not sure
    I'd have to find the jug. They took it to another job.
  16. Screwloose
    Screwloose
    When you bump into it let me know. Always looking at new ways.
  17. Screwloose
    Screwloose
    Should I get a lava lamp and loose a couple hours watching a ant hill ?
    Horkn, brenndatomu, Eric VW and 3 others like this.
  18. brenndatomu
    Contemplate the ants struggle? :whistle: :rofl: :lol:
    Horkn likes this.
