Tecomec Super Jolly Chain Grinder
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Apr 1, 2019.
  1. Chaz
    Chaz
    Southwestern NY
    Got me confused now.. I could "adapt" to a 90° from its current position, but I'd have more grind debris to worry about.
    Why rotate?
    Edit..
    I first thought you meant I reposition the grinder..
    If you mean the metal, I have enough that I can completely box in around the grinder.
    T.Jeff Veal and Screwloose like this.
  2. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I meant rotate the grinder. The crap off of the wheel goes straight back.
    T.Jeff Veal, Screwloose and Chaz like this.
  3. Chaz
    Chaz
    Southwestern NY
    I'm not seeing the benefit of rotating the grinder.
    :sherlock:
    The entire rig is on casters that are retractable, so I can position it anywhere I need.
    Having the grinder in its current alignment helps keep grit off the rails of the Shopsmith.
  4. Screwloose
    Screwloose
    I guess just try it and see what happens.
    Chaz and T.Jeff Veal like this.
  5. Chaz
    Chaz
    Southwestern NY
    Ran this chain through.. Not setup properly yet, but it is sharp.
    I think I had a setting wrong.
    I adjusted the holding unit forward 10 degrees, had it back 10 degrees when I did that chain.
    This is with it set forward.
    Rope, John D, Chvymn99 and 2 others like this.
  6. Chaz
    Chaz
    Southwestern NY
    Finished with the backsplash
    Mrxlh, John D, Chvymn99 and 4 others like this.
  7. T.Jeff Veal
    A shop vac helps to catch the dust too.
  8. T.Jeff Veal
    Something doesn't look right on the chain pawl that holds the back of the cutter.
    And it looks like the 10° is set for the wrong side of the chain.
    Chvymn99 and Chaz like this.
  9. Chaz
    Chaz
    Southwestern NY
    That is the one that was installed when it arrived. There's a 3/4" one as well.
    Should I change it out?
    As per the 10° forward or back, it seems like it gets the gullet better forward.
    But I'm a complete greenhorn here.
    :picard:
    Good news is, the chain cut well today.
    :thumbs:
    T.Jeff Veal and Chvymn99 like this.
  10. huskihl
    huskihl
    The 10° slide in vs out….picture filing a left hand cutter. Some guys drop the file handle about 5-10° and file up through the cutter. Moving the slide away from you on a left cutter allows the grinder to grind up through the tooth. On a right hand cutter, you’d slide it toward you the same amount to have the same tooth profile/shape.
    I leave my slide set at 0° for both sides fwiw. I can’t tell a difference
  11. Chaz
    Chaz
    Southwestern NY
    That makes perfect sense.
    :yes:
    It also explains why it seems to grind deeper on one side than it did for the other cutters.
    I didn't adjust it from one side to the other.
    :doh:
    Thanks for that explanation.
    T.Jeff Veal, Chvymn99 and huskihl like this.
  12. Unclefish
    Unclefish
    Northeast
    Well I tried 60 30 0 on a full chisel oregon chain .325 058 set the rakers at .022 with the stone wheel and teeth with 1/8 cbn wheel on my 550 xp.
    This did not work for me. It bogged the saw down had to work to even to get it to cut.
    I have been doing 55 25 with 10° with .022 to .025 depth rakers since the chain was new. Brought it back in and reground it back. I am cutting 3 to 4 year old oak that's probably frozen. It's eye opening when you get you angles right for your saw and wood that you are cutting. I really like testing different degrees but I keep going back to my original. Always trying to make it better easier faster cutting.
    Chaz, Eric Wanderweg and T.Jeff Veal like this.
