Super Sack
Discussion in 'The Wood Pile' started by farmer rob, Dec 22, 2018.
  1. farmer rob
    farmer rob
    Dundalk Ontario Canada
    I intend to use them for slab wood which is close to 12 months old and has been in a shed already close to 8 months in 8' lengths.I am thinking the stuff should be fairly dry before it meets my Buzz saw and then it would go back in a shed another 12-24 months
  2. Rope
    Rope
    Alaska
    I would use them in the circumstances your describing.
    amateur cutter, T.Jeff Veal and Hammy like this.
  3. Camber
    Camber
    Montana
    Give it a whirl. Remember UV is hard on them.
  4. farmer rob
    farmer rob
    I understand but they will never be in direct sunlight when full anyhow.I have a customer wanting to buy slab wood also so with the bags I can load on hay wagon and deliver them also very easy.
  5. T.Jeff Veal
    Ok, yes that wood should be plenty dry to store like that. Check your moisture down in one of your packs and see what it's like.
    farmer rob, amateur cutter and Camber like this.
  6. Mr. CJ
    Mr. CJ
    Philadelphia, PA
    Hello Guys, late to the conversation but have you seen this type of equipment that helps fill and unload super sacks. Might be useful for the wood feeding.
    FlowMatic®01 Bulk bag filling system
    T.Jeff Veal likes this.
  7. Redneck
    Redneck
    Burton mi
    Mike Morgan. has wood in some on his YouTube channel
  8. T.Jeff Veal
    Welcome to the club, lots of great folks here, sharing knowledge and humor. What kind of equipment do you have, what do you burn in?
  9. eatonpcat
    I will guess he sells bag fillers!
    T.Jeff Veal, Ron T and Chud like this.
  10. Ron T
    Ron T
    Northeast Ohio....Bowdil
    :cheers:
  11. mrchip_72
    mrchip_72
    Ontario, Canada
    I have a small garlic/onion operation. Drying these is sorta similar to firewood. The worst things for drying things I've found is to put them in a non-paper based sack.
    T.Jeff Veal and PA Mountain Man like this.
