Super Jolly Vice Won't Open
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Dec 9, 2021.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    After sharpening the righ side cutters and getting about half way through the left side the vice of my Super Jolly won't open. I see no leaks and have never found any unexplained oil on my bench. It did feel like it was catching on the way down a couple of times but it seemed to work its self out as continued on for several more teeth before it quit opening. Any ideas folks?
    Calling huskihl !
  2. JimBear
    JimBear
    I would check your lines & make sure one isn’t kinked.
    Can you open your vise with your fingers ?
    Maybe check & make sure your rails aren’t all gummed up ?
    It probably wouldn’t be a bad idea to check your oil but if it was low it most likely wouldn’t clamp.
    Can you turn your front adjustment knob to see if that breaks it free ?
    mat60, amateur cutter and huskihl like this.
  3. huskihl
    huskihl
    Never had that happen. Might be gunked up like Jim said
    amateur cutter and Ralphie Boy like this.
  4. JimBear
    JimBear
    Just an after thought on this: has that 3/32” pin come out of your cylinder/clevis ?
    mat60, Ralphie Boy and amateur cutter like this.
  5. huskihl
    huskihl
    I was out sharpening some chain tonight and I thought of this also. Wasn’t it you that wrapped some tape around it to hold it in? I ended up doing the same thing
    mat60, amateur cutter, M2theB and 2 others like this.
  6. JimBear
    JimBear
    I used a small hose clamp but tape will work. One of those fuel line clamps that are made from spring steel & about 1/4” wide would probably be ideal.
  7. JimBear
    JimBear
    Ralphie Boy have you figured out what was causing your issue yet ?
  8. Ralphie Boy
    Ralphie Boy
    Nope, I haven't looked at it yet. Probably later today.
  9. Ralphie Boy
    Ralphie Boy
    So I pulled it apart and did everything I know to do and it seems not to be a problem with the piston that closes the vice but in the big cylinder, don't know what it's called, attached to the grinder body. Flea Bay to the rescue! New hydraulic system arrives tomorrow, a bit less than I could get it any place else.
    mat60 and eatonpcat like this.
  10. huskihl
    huskihl
    Weird. Probably something stupid that you can’t see
  11. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Dissect the old one and see if you can find out what was wrong.
    mat60 and Ralphie Boy like this.
  12. Ralphie Boy
    Ralphie Boy
    UPS brought a new hydraulic unit and I'm up and sharpening again.
    Not much to to tear into. The vice plunger is basicly 3 pieces: plunger, body and cap. The seals were good on the plunger. No kinks or leaks in the line. That just leaves the pump that attaches to the grinder head and the base, and it's sealed unit so short of cutting it in half there isn't much to inspect.
    eatonpcat, Ohio and mat60 like this.
