Summertime Hoarding.
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jun 21, 2026.
  1. buZZsaw BRAD
    Hit the score today. Typical full half cord plus load cut. 241 ran solo. 462 along for the ride. 50% elm, balance of cottonwood and Norway maple. Seventh load from this location and 18th from the source. Maybe ten cords total.
    Elm rounds went into my friends shed to sleep (as MikeInMa puts it) for a year or so. The other wood was split off the truck. The general cordage Norway got stacked. 75% of a half cord rack filled. Some of the cottonwood went to fire pit inventory. Bundle splits will get moved next week.
    Four plus loads left at the score. At least one of each species. Elm will go to my friend. Ill cut at least another load next week.
    May check out a new score tomorrow.
  2. buZZsaw BRAD
    Moved all the bundle splits and the mound of nuggets on Saturday. Wood yard looking cleaner everyday.
    Checked out a score prior, but a steep hill was the stopper. He later decided to keep the wood which was some Goldilocks Norway maple and Bradford pear...the only reason I'd go after it.
    May split the remaining half cord of rounds on hand and assemble some bundles.
    RCBS, T.Jeff Veal, Woodwidow and 3 others like this.
  3. buZZsaw BRAD
    Split the half cord of red maple rounds I had waiting. Load was cut a couple months ago from my Maple Jackpot score. Thought I had an old pic, but don't. General cordage splits topped off a half cord of mixed maple. Moved the bundle splits next door.
    Pretty much caught up with processing. I have another new score to check out close by maybe today. Probably cutting another load from the current score later this week, but heavy rains forecasted will make it a muddy mess.
    RCBS, T.Jeff Veal, Woodwidow and 5 others like this.
  4. buZZsaw BRAD
    Weather changed my plans for the day so killed some time at the woodyard. Top covered a stack, moved some splits, ran the hydro a bit. Had some oak to tweak and split. One had a crotch that when split had this odd flattened football shaped object pop out that turned out to be a tennis ball that the tree had crushed as it grew. First for me.
    Checked out a potential score from FBM. Big chunks of cherry and maple. Some with rot. Not worth my effort.
  5. buZZsaw BRAD
    Did a pruning job today. Same source as post #30. Removing some larger limbs from a red maple yard tree. Couple loads of brush to the compost center. Ended up with 20% of a cord. I saved anything 3" and bigger.
    RCBS, T.Jeff Veal, Woodwidow and 4 others like this.
  6. buZZsaw BRAD
    Found this score newly listed on FBM Friday. Lady replied right away and I grabbed the "decent" mulberry yesterday. Easy park and load save for the big trunk chunks. Spent some time editing them with the battery saw here. Ill split it tomorrow at storage. Saved some sawdust for cold smoking some cheese when the weather cools. Here's the FBM link.
    https://www.facebook.com/share/19QfFfYfZF/
    Keep in mind mulberry is a scarce tree (and rare score) around here and seems it doesn't get that big before its cut so any found ill gladly take.
    RCBS, T.Jeff Veal, Woodwidow and 6 others like this.
  7. theburtman
    theburtman
    One of my neighbors who spends winters in Florida, brought me 2 loads in his side by side of what was standing dead barkless that has fallen. He thinks one load is oak. That should make some heat! Anyway, this is my favorite kind of summertime hoarding.
    RCBS, EODMSgt, T.Jeff Veal and 4 others like this.
  8. buZZsaw BRAD
    Special thanks to buzz-saw for some fresh cut Goldilocks red maple I grabbed at his place yesterday. :handshake: Processed that along with the mulberry from Saturday right off the truck yesterday. Stacked the maple from that and Fridays job in a temporary spot. Maybe a face cord total. It will get moved when a rack opens up for it.
    May hit the current score over the next few days as it shouldve dried enough.
  9. buzz-saw
    buzz-saw
    Ct.
    No problem. Figured you are always looking for Maple so I will keep you in mind.
    RCBS, Stephiedoll, eatonpcat and 4 others like this.
  10. buZZsaw BRAD
    A familiar event happening today. SWEET score popping up changed my current hoarding plans.
    Customer of mine was having a tree taken down which I knew about. Nice black birch maybe a face cords worth of wood. Turns out they took a few more trees down too...Goldilocks sized beech. 3-4 truck fulls is my firewood educated guess. Staged next to the driveway so I can buck and load easily. A mile from storage to boot.
    Guessing black birch are better than cottonwood and elm? :whistle:
  11. T.Jeff Veal
    Great scores and work, my friend.
    You have been busy
  12. MikeInMa
    Nice scrounge!
    Hot days ahead. Stay safe.
  13. buZZsaw BRAD
    Hit this new score for the first time this morning. Turns out there was four trees taken down. Cut most of the birch then a couple beech logs. 462 did the honors. Not a typical Brad load (less than heaping) as I wanted to split some off the truck and hit my "other job" later. Split all the beech rounds after at storage. Ill split the birch off the truck tomorrow. Couple truck loads left to cut. Not sure when I'll cut the next load.
  14. T.Jeff Veal
    Git'ter done
  15. buZZsaw BRAD
    Split the birch off the truck. It will be added to an existing stack of such. With the other birch log there it should top off the half cord stack. Have a couple half cord racks partly filled with some smoker wood ill move next door to make room for the beech. Not sure when I'll cut the next load. I should really move and stack first.
  16. buZZsaw BRAD
    Stacked the birch and beech from the other days cut. Need a bit more birch to top off a half cord. Moved some smoker wood to free up a rack for the beech. Roughly a quarter cord each. Going in the morning to cut the second load from there.
    Got a text from an old friend. His BIL took down a tree in his yard yesterday that turned out to be TOH. I checked it out today. Inundated with spotted lantern flies. He had bucked some of the limb wood, but 75-90% of the tree intact. I can back right up to it to cut and load. Probably get it by months end. He showed me a few other trees I can take down. I drive by the house en route to the wood yard almost daily. I scored wood there twice back on 2020.
    Found Myself Another Honey!
    I Love You Honey!
    RCBS, EODMSgt, Michigander and 5 others like this.
  17. theburtman
    theburtman
    According to my calculations and using the differential for thrown vs stacked, I have 1.3 cords of lumber cutoffs so far for the upcoming heating season.
    RCBS, EODMSgt, MikeInMa and 5 others like this.
  18. buZZsaw BRAD
    Well I was all set to go cut a load of beech and birch this morning, but found a new listing on FBM in my hometown. Black locust and TOH.
    Guy responded this morning. I arrived at 1030 and to my dismay another hoarder already there and he's cutting the BL. :hair: He finished taking what he wanted, we chatted a bit (turns out he bought BL from me a couple times a few years back) and left. My turn for BL. Cut the rest of the large tree and loaded. A large barkless limb that had been down a few years was cut next. Took a water break to talk with the homeowner and ANOTHER hoarder shows up for BL. Last tree was on the smaller side. I got a couple 4' sections and they got the rest. The homeowner divided it up among us. Ended up with close to a full load. I texted a pic to Eric Wanderweg to prove it did happen.
    I saw the two guys who showed up after me checking out the TOH. I guess they didn't feel like schlepping it out. Cant blame them. Lantern flies were all over the place. I must've killed ten of them while I was there.
    RCBS, EODMSgt, Eric Wanderweg and 6 others like this.
  19. Eric Wanderweg
    Mandatory “pics or it didn’t happen” shot:
    :dex:
  20. buZZsaw BRAD
    Thanks buddy! :handshake:
    T.Jeff Veal and Eric Wanderweg like this.
