Suggestions on which pellets to purchase
Discussion in 'The Pellet Bag' started by Hitch, Oct 20, 2014.
  1. savemoney
    Try some high temp aluminum tape. Slick fix many times.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    The 1st connection (vent to stove) should absolutely have a good bead of high temp silicone/caulk (500° minimum).
    A pellet stove has a positive pressure exhaust. So any spot that does not have a good seal? Will leak and that leak is letting CO into your home.
    IHATEPROPANE likes this.
  3. 343amc
    343amc
    Northeast Lower Michigan
    Don't feel bad. My stacks look like I was knee walking drunk when I piled them up. The first ton gets stacked OK, then my give a darn shrinks the farther I go. The important thing is they are off the ground, they aren't falling over, and come spring, nobody but me will remember what they looked like.
    Welcome to FHC.
  4. jtakeman
    I may not start that way, But by the end of the ton I'm usually pretty gosh darn close!! ;)
    :drunk:
    will711 likes this.
  5. Hitch
    Hitch
    Outside Philadelphia
    Well, here's the final stack. We got all of the pellets out of the garage (top picture in my other post) and down into the basement. I think it's a decent stack - certainly no longer borderline pellet abuse. :D
    Birddog91, will711, imacman and 4 others like this.
  6. will711
    will711
    Pocono Mts.
    Look at all those little beauties ,just waiting to be turned in to Btu's :thumbs: :fire::dancer:
    smoke show likes this.
  7. eatonpcat
    Doesn't matter how you stack them, they will burn the same!!
  8. PelletHound
    PelletHound
    SE Ma.
    I've seen worse.Much worse.:emb:
    will711 and IHATEPROPANE like this.
