Suggestions on how to use this shed...?
Discussion in 'The Wood Pile' started by DarinD, Feb 28, 2020.
  1. FatBoy85
    FatBoy85
    Washington State
    Maybe just a couple of rounds for foot rests!
    amateur cutter, Stlshrk, Loon and 5 others like this.
  2. Chaz
    Chaz
    Southwestern NY
    X2 ^^^
    :yes:
    amateur cutter, Stlshrk, Loon and 4 others like this.
  3. Backwoods Savage
    Air flow should not be a problem at all. So many seem to think you need single file stacks when it is not necessary and also makes the stacks weaker rather than stronger. Many end up re-stacking because of it.
    The most I remember stacking rows together was 21. No. There was absolutely no problem drying the wood. But typically we mostly tend to stack 3 rows together and have never had a drying problem. So I say if you want to stack wood around the shed, by all means do it but stack more than one row together to give it some strength.
    Best yet though would be to put slats up on the sides. They do not have to be big slats. A 1 x 3 or 1 x 4 works great. Even a snow fence will work great.
    amateur cutter, Stlshrk, Loon and 8 others like this.
  4. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Oh man, that looks very unstable, you should take it down... I would be happy to take it off your hands... For your safety. :whistle:
  5. Stlshrk
    Stlshrk
    Central Virginia
    If you don't intend to use it for wood storage, then I recommend filling it with something Orange, Blue, or Green. Diesel powered, of course! :tractor:
  6. mirnldi
    mirnldi
    Ct
    Darin D’s outdoor bar and grill. Outdoor kitchen. Already has power. Build a small bar, hang a tv, few chairs. You’ll be the life of the neighborhood for 3 seasons!!
  7. Reloader
    Reloader
    NW Oregon
    If you use it for wood storage, consider leaving two sides open so you can empty 1/2 then refill it while using the other 1/2. That way all of the wood gets used in a year or two.
  8. buZZsaw BRAD
    i see an area for using a splitter even in bad weather. Enclose the sides
  9. amateur cutter
    My thoughts as well. Under cover splitting area, lighted for those short Winter days.
