Suggested Spare Parts
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by wildwest, Oct 20, 2015.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    Time to practice so you know how with your eyes closed, just saying
  2. wildwest
    Bookmarked, thanks. I still have 3/4 case of super cedars from when wood was our heat source. Wood still is on the super cold days, but the Drolet does most the work :)
  3. subsailor
    subsailor
    Winthrop, Maine
    I've been meaning to start my stove manually just to understand how or if it feeds the same but I never seem to get to it.:confused:
  4. subsailor
    subsailor
    Winthrop, Maine
    I use a propane torch.
  5. jtakeman
    Automatic(auto ignition) propain torch used with map gas for the extra umph!! Works like a charm.
    I started the stove as normal, Once the pellets stop dropping for the initial start up cycle. I opened the door and hit the pellets that loaded for about a good minute or so. Too long and the stove controller will fault out for no vacuum. Closed the door and watched for a bit. If it didn't start making decent flames I'd open the door and hit them again JIC. Don't move the torch around hold it in one spot the get them glowing. Then move them to another spot if needed. One good blast usually is enough.
    I kept my stove going for a couple of weeks while waiting on parts to arrive. Igniter arrived in days. But the controller too a bit longer to get. Mine lost the relay in the ignition circuit but still ran the stove NP. Just wouldn't power the new igniter/air pump.
    ivanhoe, wildwest and imacman like this.
  6. IHATEPROPANE
    IHATEPROPANE
    I manually lit my stove using the torch method and the hand sanitizer method. The sanitizer method I found to be much easier. I would take a small handful of pellets, put them into a Tupperware container, load it with hand sanitizer (higher alcohol content the better) and shake. Dump them in the pot and light. Once it looked they they took, I would start the stove with the door slightly ajar as to not blow out the weak flame. Soon enough you will see when they really take and you can shut the door completely.
  7. Arti
    Arti
    Southern Wisconsin
    I bought a used stove that is the same make and model to the one in the living room from Craig's list, Paid $250. for it .
    Lit it up to make sure it works gave it a good cleaning sprayed it down with oil before we put it in a storage shed.
    CleanFire, ivanhoe, wildwest and 2 others like this.
  8. Lousyweather
    Lousyweather
    MAPP gas!
    imacman, CleanFire, ivanhoe and 3 others like this.
  9. wildwest
    Nice to see you Kevin :)
    CleanFire and ivanhoe like this.
  10. jtakeman
    :yes:
    Isn't much more $$ around here, But makes a big diff in the heat the torch yields! A good minute blast is like almost 2 minutes or so with porpain!!
    CleanFire, ivanhoe, eatonpcat and 4 others like this.
  11. Lousyweather
    Lousyweather
    yea...cant believe folks still swet pipes with regular propane.....propylene is where its at!
    CleanFire, ivanhoe and wildwest like this.
