Suburbanite wood stacks
Discussion in 'The Wood Pile' started by Polvalt, Mar 8, 2015.
  1. MrWhoopee
    MrWhoopee
    Shingletown, CA
    That's my recommendation. Fence the entire property. I takes up the least amount of useable space in your yard and you're protected from stray bullets. ;)
    splitoak, Horkn, HDRock and 5 others like this.
  2. bassJAM
    bassJAM
    Cincinnati, OH
    I remember your post about getting a large tool box up a hill. Do you have to tote all that wood up there by hand as well?
  3. Backwoods Savage
    Welcome to the forum Polvalt.
    Good that you can stack somewhat like Jon. It should serve you well with a couple exceptions. I would definitely not want to be burning oak because it takes too long to dry and without ideal drying conditions (no air circulation), it could take 4-5 years to get good and dry like you need.
    Also the cubes and fences are good choices. I wish Flatbed Ford was a regular on the forum as he has a small lot but makes it work great and he even burns a lot of oak. But he does have better air circulation.
    Okay, others posted so here are a couple pictures of some of ours. Stacking like this you can go quite high and the stacks will still be stable.
    splitoak, greendohn, Polvalt and 5 others like this.
  4. MightyWhitey
    MightyWhitey
    Listen to this guy^^^^^^!!!!!
    Right now I'm burning 2+year old CSS white oak.......................and I have occasional problems with it trying to get it going in my 13 NC........................especially in a cold stove!!! I believe it's because of the "bark" that's still very much "attached" to my 2+ year old CSS white oak!!
    Only happens with my oak though!!
    I don't.................and you won't run into that problem with.................."the lesser woods"........................like many here disregard. Prior to this winter; I heated my house almost solely with silver maple and box elder....................with a little bit of "ash" in between!!!
    I've only been burning for 3 winters now; but I thank God every day that I didn't (and haven't since) disregarded burning Box Elder or Silver Maple, like many here do!!!!!
    If I can "learn" you anything, it's this...............................Listen to Backwoods Savage!!!:thumbs::cool: He knows more about burning wood than most of us will ever forget about burning wood!!!!
    Just saying of course!!
  5. Jon1270
    Jon1270
    Pittsburgh, PA
    No, it comes down from above. It's still a pain, but at least gravity helps, and it's a shorter distance than from below.
  6. Greenstick
    Greenstick
    Wish I had pics...first house mama bear and I rented we/I lined the alley and one side about 50 feet with double rows of wood. Stacked about 5 foot high. Rite away mama said its gonna look bad but I did it anyway. After a month she admitted as long as it isn't in a heap she liked the privacy and it kinda looked neat having a fence that nobody has like it and looks kinda rustic.
  7. MightyWhitey
    MightyWhitey
    So you can walk around "Armed", hey??!!!!:D:cool:
    Backwoods Savage and Greenstick like this.
  8. EvilRoySlade
    EvilRoySlade
    image.jpg 90x120 lot. If you found this site, you'll find a way to make it work.
    Sorry, inlaws. Wish it was mine.
    This is one side of my house. Other side is less neat. I move wood too much but one of these is always 3+ yrs old
  9. Horkn
    Mighty, oak is the only wood that takes 3 years of regular drying time. There are much better woods that make more btu's that can dry regularly like shagbark hickory and others. Oak is good, no doubt, but its picky and due to longer drying times, may not be best suited for small suburban lots, unless a solar kiln is used.
  10. Horkn
    For me, I've got an acre in the burbs. I will start a stack row as a fence on the north west corner. I'll probably try a solar kiln or 2 as well. Stacked on skids, chimney corners to keep it perty.
  11. HDRock
    I have never burned shagbark before but I have a bunch drying out now, how long do you estimate drying time for it?
  12. Horkn
    It might be ready for next season. It should really, but only a moisture meter will confirm. I've had good results of drying shagbark over a summer. This was pre mm checking days though, and simply going on how well it burned.
    HDRock likes this.
  13. Polvalt
    Polvalt
    Eastern Washington
    Thanks for the insight. Around here, I don't think I'll be using much oak. Most of the people I know near by, who heat with wood, burn red fir and tamarack. It is pretty easy to track down here...
    Backwoods Savage and Horkn like this.
  14. Horkn
    Those are quick drying woods iirc. That helps with your lack of space for stacks.
  15. billb3
    My sister lives on a corner lot with the house set as far back from both streets as possible so mostly all front yard.
    She'll stop by my house every Sunday afternoon and pick up about a third+ of a pickup load which gets stacked in one of those plastic garbage can sheds.
    I've stacked as a privacy fence and hope to have a longer "fence" this Spring before the bugs get nasty and the garden takes up my spare time.
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Yea, I have to pick up the pace on getting things cleaned up. City says a max of 1 year worth of wood, but hey, it takes 3 years to dry :).
    Hope to have the driveway cleaned up this weekend. So far, neighbors seems OK with it, but I know I am pushing things hard.
  17. rayvil
    rayvil
    Maryland
    I'll take all the Oak I can get my hands on. 2-years is all it takes.
  18. billb3
    Usually keeping the neighbors happy (eyesore ) alleviates infringements on the collective's rules. You get a elitist neighbor who thinks he knows best how you ( and everybody else ) should live that might not work. :)
    Beauty is in the eye of the beholder is why fences often make for good neighbors.
    You got some nice fence going on there.
    Horkn, Backwoods Savage and jetjr like this.
  19. JustWood
    JustWood Guest
    One years worth of wood is a relative term.
    That said. My old man burns 20 cord a year.;):cool:
  20. Backwoods Savage
    Well Ray, you can burn it in a year too if you take a liking to it. But then, some are happy with second best.
    Horkn likes this.
