Submersible wood stove to heat small pool
Discussion in 'The DIY Room' started by BrianK, Dec 20, 2016.
  1. Gasifier
    :rofl: :lol: Hey, you stop misquoting me. I don't know what your talking about. :DWe all know you can change those quotes!
  2. BrianK
    BrianK
    West central PA
    I already have the pool and can just heat it with the electric spa heater that came with it.
    In this case all the maintenance is really just part of the ongoing rehab and therapy.
    Plus I hate public pools and gyms.
  3. Gasifier
    Then that settles that. Now, how is the stove regulated? Thermostat in pool water control whole thing?
  4. BrianK
    BrianK
    West central PA
    No, it's controlled the old fashioned way: if it ain't warm enough, load more wood and open up the draft.
  5. Gasifier
    Oh. The good, old fashioned way. Eh Doc?
    343amc, Jack Straw, BrianK and 4 others like this.
  6. Horkn
    I was thinking about posting that picture. :thumbs:
    BrianK and Gasifier like this.
  7. BrianK
    BrianK
    West central PA
    Gasifier and fishingpol like this.
  8. BrianK
    BrianK
    West central PA
  9. BrianK
    BrianK
    West central PA
    Oh, and I decided to use the rocket stove and masonry bench to heat the water. Someone just posted two unopened 1/2" by 50' rolls of flexible copper tubing on Craigslist for $40 each. I'll wrap one around the top of the rocket stove barrel and run one in long loops inside to top of the 8' masonry bench; I can get a decent 12v circulator pump for $49, which I can run with my battery jump starter plugged into 110v to keep charged. About $30 worth of CPVC 1/2" pipe should do it for the hot and cold lines from the pool to the rocket stove and they gave me a big bag of various copper couplings with the copper tubing. A lot cheaper than the submersible wood stove and I don't have to figure out how to vent it. In the future I can charge the 12v battery with a TEG generator too.
  10. brenndatomu
    Hopefully this works out for you. I have read of people doing something similar to heat their domestic water, sometimes it works, sometimes it doesn't. I suppose the devils in the details...
    BrianK and Jack Straw like this.
  11. BrianK
    BrianK
    West central PA
    Well, I have two 50' sections of 1/2" flexible copper tubing plus two 6' finned copper baseboard heater sections to pick up the heat from inside the 8' rocket heater masonry bench. I have a 5 gallon per minute circulator pump. I only have to heat a room temp 2400 gallon pool up to 85 degrees. From what I've read and been told this shouldn't be hard to achieve.
  12. Gasifier
  13. brenndatomu
    That might be one of those details that I mentioned before that causes problems.
    5 GPM through a 1/2" pipe is pretty high velocity, which is bad. You want a lower velocity so that the tubes have contact time to be able to pick up and then give off (transfer) the heat. Think of it like this, its kinda like when you pick up a hot baked potato, if its too hot for you, you'll "juggle" it...by doing so you are lowering the contact time and therefore the heat transfer. Easy enough to find a smaller pump later on if it is an issue.
    Hope you'll keep us updated with pics and such, the build on that rocket heater masonry bench is going to be fun to watch, those things are sweet! Just FYI, Eric VW may be able to provide insights on building that, I believe he has played around with 'em in the past.
    Popcorn for breakfast?! ;) :rofl: :lol:
    BrianK, milleo and Eric VW like this.
  14. Eric VW
    Great point on smaller pump capacity. :yes:
    Me and BrianK have an ongoing PM on the subject, too..... but I appreciate ya giving the shout out brenndatomu :)
  15. BrianK
    BrianK
    West central PA
    Thanks.
    300gph (5gpm) was the only 12v pump I could get at Harbor Freight. I can order a 2 gpm pump online and I will if this one doesn't pick up enough heat. I'm running through 100' of 1/2" copper refrigerator tubing and 12' of finned 3/4" copper baseboard heating element which is a lot more copper than I've seen in YouTube videos so I'm hoping the length of copper makes up for the higher flow rate.
    Eric VW and Canadian border VT like this.
  16. BrianK
    BrianK
    West central PA
    Well, they had the smaller pump in stock today so I traded the 5 gpm pump on a 3 gpm pump. We'll see what happens.
  17. BrianK
    BrianK
    West central PA
    I posted photos of much of the rocket stove build here if you're interested:
    Affordable commercial vacuum formed ceramic fiber riser | Rocket Stoves.. Experimenters corner.. Answers questioned!
    brenndatomu and milleo like this.
  18. BrianK
    BrianK
    West central PA
