Submersible wood stove to heat small pool
Discussion in 'The DIY Room' started by BrianK, Dec 20, 2016.
  1. yooperdave
    Thats the practical side of you kicking in!
    Eric VW, Horkn and XXL like this.
  2. BrianK
    BrianK
    West central PA
    They come with a long handled deep 90 degree shovel but they only need emptied once a week.
    Eric VW, Horkn and yooperdave like this.
  3. BrianK
    BrianK
    West central PA
    Thanks Pete. I think that's why marine grade aluminum is the gold standard in submersible stoves. It's resistant to the chlorinated water - but expensive and not as easy to weld.
    Eric VW, Horkn and Pallet Pete like this.
  4. BrianK
    BrianK
    West central PA
    Thanks. I have a working electric inline spa heater that came with the pool. The pool is 2400 gallons, a lot more water than a small spa heater is designed to heat.
    I could run pex tubing from the pool to a rocket stove I've built in another part of the same basement 30' away, and run loops of copper tubing inside or outside the barrel of the rocket stove or the masonry bench/bell I'm heating with the rocket stove. I like the idea of heating it with wood but I didn't want to get into pumps with running the pex that far.
    Horkn likes this.
  5. BrianK
    BrianK
    West central PA
    walt my brother TurboDiesel thinks you might know something about this subject?
    Horkn and TurboDiesel like this.
  6. walt
    walt
    north central ohio
    Yes Brian I have a sornkel stove and it works great.
    Before we got this I was thinking about building a therm-o-siphon system, did some research on You Tube
    I think the alum. stove in the water is the best way to go I can go two or three days of cold weather and not have a problem with freezing.
    We have had couple inches ice on top build a fire and its all good
    Therm-o-siphon you will worry about lines freezing and the water jacket stove.
  7. BrianK
    BrianK
    West central PA
    Fortunately this therapy pool is in the basement, so I really hope freezing pipes never become an issue!
    Do you have any photos of your set up? Does the stove have any internal baffles? How is the ash removal process?
    Horkn likes this.
  8. BrianK
    BrianK
    West central PA
    Horkn likes this.
  9. brenndatomu
    Not until you get to very high concentrations (unless it is a very low grade stainless) pool water is well below that threshold.
    Plate steel will work for a while...but it will begin to degrade pretty quickly.
    Horkn, BrianK and Pallet Pete like this.
  10. BrianK
    BrianK
    West central PA
    Eric VW and Pallet Pete like this.
  11. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Stainless discoloration happens very fast if it's submerged even in small amounts but structuraly it won't have much effect unless its higher volume.
    Good point!
    Eric VW and Horkn like this.
  12. Pallet Pete
    Ovid
    I need to find that teg light I made. Thermoelectric generators are sooo cool!
    Eric VW, Horkn and BrianK like this.
  13. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Can't you use something other than Chlorine?
  14. Horkn
    Yes, chlorine and regular steel are no bueno.
    That TEG is very impressive.
    Eric VW likes this.
  15. Horkn
    Salt. But that is a bit corrosive too.
    Eric VW likes this.
  16. Unicorn1
    Unicorn1
    Amarillo, TX
    I can't wrap my head around a small pool in a basement.:eek:
    Eric VW, BrianK, Horkn and 1 other person like this.
  17. brenndatomu
    I work for the city water utilities and customers usually do have a hard time wrapping their head around the "pool in their basement" when their sewer plugs up! :picard: :hair:
    More on topic, we clean tanks using HTH (powdered chlorine) making solutions up to 50 mg/l with no ill effect on the stainless steel parts. IIRC it takes more like 200 mg/l to start causing problems
    Horkn likes this.
  18. BrianK
    BrianK
    West central PA
    Actually this is the second one for me. When the kids were smaller I had a 10'x15' oval above ground pool in the basement of my house in Johnstown. We had a heat pump pool heater from a 28' round above ground pool that I found used online at the time. I could get that thing up to hot tub temps pretty easily.
    I'd never put one in a finished basement. But that pool is a giant heat sink that slowly heated the house. We saved far more in natural gas to heat the house than we spent in electricity to run that heat pump to heat the pool at the time.
    But we're living with my mom now to help keep an eye on her and I don't want to put up her electric bills if I can use my wood to heat the pool.
    Horkn and Eric VW like this.
  19. Gasifier
    Canadian border VT said this: just out of curiosity isn't there an easier way..
    Yes. And after reading a little of this and thinking about it......
    Brian. Are there any Colleges close by that you can buy a membership to there gym facilities ? We have a couple where you can get a single or family membership for the year and use everything they have. Which is a lot and includes huge pools to swim in.
    It may be much easier to not have to go through all your going to have to do and then maintain and do the whole wood thing to bring it and keep it to temp.
    (I don't know all of your circumstances, so bear with me here man.)
  20. brenndatomu
    You a brave one...asking the man to "bare" in a pool thread! :whistle: ;) :rofl: :lol:
    Horkn, Eric VW, BrianK and 2 others like this.
