stuck piston rings.....what's the secret?
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Oct 20, 2016.
  1. Grizzly Adam
    Grizzly Adam Guest
    Is that the degreaser or the all purpose cleaner?
    NortheastAl likes this.
  2. Warped5
    Warped5
    Northwest IN
    I got the Large USC at HF .... does do heat.
    Yep, use regular SG in a 50/50 dilution with water. It will discolor aluminum a little bit.
    Note: The SG Pro HD will take the shine off of plastics.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I have the P4830 on this page. i use it to clean my reloading brass, also to clean whole handguns and the ever infamous AR BCG. Works fantastic.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    The regular green stuff. I believe its a phosphoric type cleaner. I have some anhydrous citric acid that works well on brass, dawn dish soap is a great surfactant for US Cleaners. Lowers the srface tension of the water so the vibrations work better..... (quick and dirty there huh)
    Dancan, NortheastAl and eatonpcat like this.
  5. 94BULLITT
    94BULLITT
    Frederick County, VA
    Try carb cleaner.
  6. Scotty Overkill
    I tried everything, fellas........except for Kroil. Trust me when I say they are STUCKETY-STUCK to the STUCKTH DEGREE.
  7. Scotty Overkill
    I may have to buy one of those if my current idea fails.....
    NortheastAl, Horkn and Woodsnwoods like this.
  8. Redfin
    Redfin
    central Pa
    Scott, we can through that in the ultrasonic machine if all else fails. 50/50 acetone and atf is also a wonderful lubricant. Id heat the lands and spray it on.
  9. Scotty Overkill
    Thanks man, if all else fails I'll send it up your way. I'm almost at the end of my rope....:headbang:
  10. bushpilot
    bushpilot
    Eastern Washington
    ATF / Acetone mix is said to be the best, with Kroil second. Can't vouch personally for the mix, but Kroil is quite good, as is Mouse Milk. I have used both, but not in a way that I can compare the two.
    As I said though, I have heard ATF / Acetone beats them all, not tried it. Google it.
  11. TurboDiesel
    you sure?!? ...:confused:
  12. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Atf and acetone is amazing, I gave my can of Kroil to a friend. If it doesn't work try molasses and water .
  13. Scotty Overkill
    Crap....I guess we don't anymore!!!
  14. eatonpcat
    We have one here...If you happen to pass by this area somtime soon, maybe you can pick some up for Scotty!! ;)
    This was for TurboDiesel
  15. Scotty Overkill
    I'll get some acetone tomorrow after work and give the ATF/acetone concoction a try.
    clemsonfor, NortheastAl and bushpilot like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    In a crock pot, on warm..... if your willing the risk of fire, it works.
    clemsonfor and NortheastAl like this.
  17. Elderthewelder
    Elderthewelder
    Washington State
    I guess I'm spoiled, I can pretty much get all the kroil I want through work..I work in the aviation industry so all chemicals have a experation date on them , once expired they can't be on the floor anymore and get turned into hazmat for disposal and I am friends with the hazmat lead. Plus there are always partial cans of it in the chemical cabinets that end up going home with people
    Dancan, thistle, clemsonfor and 3 others like this.
  18. Redfin
    Redfin
    central Pa
  19. Redfin
    Redfin
    central Pa
  20. TurboDiesel
    A bath and a movement.o_O
    :dex:
