Straight gassed BR600
Discussion in 'Chainsaws and Power Equipment' started by basod, Apr 27, 2015.
  1. AJtree88
    AJtree88
    The problem with straight gassed 4-mix blowers is that the wrist pin seizes and takes out the crank since they don't use a roller wrist pin bearing like saws. It's just a tight fit like a plain bearing.
    Jon1270, rookie1, basod and 2 others like this.
  2. MasterMech
    That was really only an issue with early production units and was fixed with a material change early on. If you have a BR600 that's not a first year unit, it's most likely got the new valves. Was pretty nifty to see an exhaust valve stuck in the piston upside down like a daisy. :rofl: :lol:
    The other issue was with some commercial operators especially, they would over-rev/overheat the engine and it would slip the exhaust valve guide.
    XXL, basod and Fanatical1 like this.
  3. basod
    basod
    Mount Cheaha AL
    any recollection on first year unit production time frame?
  4. MasterMech
    I knew somebody would ask me that. Lol
    I want to say 2006-7. I'm not sure. I could look at mine when I get home next week as its a fairly early unit.
    XXL likes this.
  5. basod
    basod
    Mount Cheaha AL
    This ones newer than that 2009-2010ish
    XXL likes this.
  6. MasterMech
    Should have all the updates including the dual pickup fuel line. All early BR500/550/600 blowers had a tendency to starve for fuel with less than half a tank in them.
    basod and XXL like this.
  7. NewToStihl
    NewToStihl
    Central Indiana
    Some notes. First, you'll have to cast aside the "higher compression is better" 2-stroke mindset. The Stihl 4-mix engines aren't intended to have the high compression of chainsaws, and if I recall they have intentional/built-in decompression. My memory sucks, but I think the optimal range for them is somewhere around 115-125psi or something??
    Second, if you're looking for a replacement engine it's good to know that the BR550 and BR600 have the same engine, so your options are opened up a bit.
    Lastly, it's absolutely not a 4-stroke engine; it's a 2-stroke engine that has an exhaust/intake valve configuration that optimizes the transfer of fresh fuel intake and exhaust discharge. It still creates combustion each time the piston reaches TDC (i.e. 2-stroke). They called it a 4-Mix because of the valves. They no longer call it a "4-Mix", but rather a "low emission engine" or "reduced emission engine" or something like that. I'm told the name change was due to too much confusion between 4-cycle and 4-Mix and too many folks using straight gas. Despite the name and the valves, another reason I've noticed it's often confused as a 4-stroke is the lower RPM at WOT. It certainly takes some getting used to because they run several thousand RPM lower at WOT.
  8. fox9988
    fox9988
    NW Arkansas 72717
    I haven't read about 4-Mixes in years, but I remember them being a 4 stoke= 4 strokes per firing, fire every other time the piston reaches TDC.
    The difference being: the crankcase lube is mixed in the fuel and circulates through the crankcase.
    MasterMech likes this.
  9. MasterMech
    fox9988 is absolutely correct. The 4-mix is a 4-stroke engine with a total loss lubrication system. It runs the fuel mix through the crankcase like a 2-stroke but dedicates an entire stroke to suck, squish, bang, and blow.
    Some of the trimmer engines tach out to 10-11k RPM, which is plenty zippy. They just sound deeper and slower because they only fire half as often as a two-stroke turning the same RPM.
    They do indeed have a built in de-comp bump on the cam lobe. One cam lobe runs both valves due to the special geometry of the lifter arms.
    basod and fox9988 like this.
