Stove Tetris
Discussion in 'Everything Else (off topic)' started by bobdog2o02, Jan 17, 2016.
  1. Horkn
    Not as long as I expected, as there was a bit of pine in it. I just reloaded the stove from it. 10 hrs according to the times on FHC when posting. But I could've rechooched it a couple hours ago to keep stove temps higher.
    T.Jeff Veal and Stihl Kicking like this.
  2. EODMSgt
    EODMSgt
    White Mountain Region, NH
    Definitely jealous of those that can load their stove N/S. E/W loads have worked well in the Regency for the last 12+ years however it does require more maintenance than if I could just do a full N/S fill. I could cut smaller splits (been using 16"-18" since I purchased the stove in '09), however it's not something I really want to do.
  3. theburtman
    theburtman
    My stove will take 22 inch splits EW. I cut 18 inches and it seems to work well. Fires last through the night and will easily relight from coals when I get up. I really don't want to cut splits in half to gain maybe 2 more hours of burn time by loading N/S. On the other hand, I do sometimes do a hybrid. A couple shorts from going N/S and 18 inch splits going E/W. It's good way to use shorts.
    Slocum, Stihl Kicking and EODMSgt like this.
  4. EODMSgt
    EODMSgt
    Yep, I experiment with N/S loads when I'm burning shorts. I've become very adept at starting my E/W splits usually only using one piece of fatwood and maybe one piece of kindling, and I always have good burns, so the only real advantage I would see to the N/S loads is that I could fill the box for longer burns (I don't like anything up against the glass, so I never fully load E/W.
  5. rdust
    rdust
    SE, Michigan
  6. Stihl Kicking
    Stihl Kicking
    Missouri
    I tried my hand at an E/W tetris, but of course when keeping it off the glass you can't stuff it as much. And really this is more of a hybrid, as I used a few small cuts N/S to fill in the ends.
    My first back row, and end filler. (already wanting to catch fire)
    The end result.
    Question.... Is there such a thing as a truck tetris?
  7. Ohio
    Not Ohio
    All ash. I used to have a smaller stove and now my splits are a bit short for the fireview. I saw some and add them to fit in between the splits and the door.
    Thor, HDRock and T.Jeff Veal like this.
  8. T.Jeff Veal
    Every time we deliver a truck load to a customer. We fill in the empty spots around the wheel wells and tailgate. 0118220951_HDR.jpg
  9. T.Jeff Veal
    Thor, HDRock, rdust and 7 others like this.
  10. blacktail
    blacktail
    PNW
    A full tank of alder and hemlock.
    Thor, Ohio, HDRock and 9 others like this.
  11. rdust
    rdust
    SE, Michigan
    Thor, Ohio, HDRock and 6 others like this.
  12. T.Jeff Veal
    rdust and Stihl Kicking like this.
  13. rdust
    rdust
    SE, Michigan
    It’s been a while, not a full effort load but it’ll do.
  14. PatrickNY
    PatrickNY
    Putnam County, NY
    I’m still pretty new to the wood burning game, but it seems like if I put that much wood in my wood burning stove, I’d get the house up to 95-100°F. After I get the fire going, I just put a couple of logs in at a time and that keeps the house around 70-75°ish. What am I missing? …or does packing the stove full just make it last longer as long as I don’t give it too much air?
    T.Jeff Veal and rdust like this.
  15. rdust
    rdust
    SE, Michigan
    With my stove the amount of wood added doesn’t change output just run time. Think of it like a fuel tank in a car. The more fuel it can hold the longer you go between fill ups.
    T.Jeff Veal likes this.
  16. Ohio
    Not Ohio
    Load of pignut hickory to the gills.
    Thor, blacktail, rdust and 2 others like this.
  17. Horkn
    Well, didn't think I'd be attempting to fill the stove even close to full in late March, but this weather...
    Thor, HDRock, blacktail and 3 others like this.
  18. Ohio
    Not Ohio
    First stove Tetris post of the burning season WOOOOOooooooO. Not getting too serous stuffing it to the gills. Mostly tulip poplar, a piece of cherry and two splits of white oak. 1113222104a_Film2.jpg
    Thor, HDRock, Softwood and 7 others like this.
  19. T.Jeff Veal
    Looking good. We had a mix last night too. Tulip poplar, oak, beech. cherry
  20. rdust
    rdust
    SE, Michigan
    3334B19A-CABE-4A13-AB2D-83096F0F4003.jpeg Stove has a full belly of ash so not a huge load but it’ll be good enough. About as much ash as I could fit on top of the ash. :rofl: :lol:
