Stove Tetris
Discussion in 'Everything Else (off topic)' started by bobdog2o02, Jan 17, 2016.
  1. Eric VW
    That's one hot tamale :bug:
    :yes:
    Chvymn99, HDRock, Horkn and 1 other person like this.
  2. rdust
    rdust
    SE, Michigan
    Low single digits tonight.
    Chvymn99, HDRock, Horkn and 2 others like this.
  3. bushpilot
    bushpilot
    Eastern Washington
    This one hit 750 (IR gun), with the air closed completely. The secondaries were really cooking!
    That is the highest temperature I have seen on this stove yet, I didn't want it that high for the overnight burn, but it worked out OK. My mistake was that it was too much of a coal bed to start, and it just took off.
    Englander doesn't specify a maximum temperature for this stove, just that it shouldn't be glowing. Well, it wasn't glowing! The STT guage indicated "too hot" and the flue gauge was about 750 as well.
    Buzz Benton, Chvymn99, HDRock and 3 others like this.
  4. TurboDiesel
  5. Eric VW
    Is that in the living room?:whistle:
    :hair:
    :bug:
    I'm sure it's not, you'd melt.....:D
  6. rdust
    rdust
    SE, Michigan
    Will probably glow around 900, all is good! :rofl: :lol:
  7. TurboDiesel
    Concrete in front of stove in basement.
    Probably 85 degrees down here but I've got a little sinus congestion and sore throat, so I'm sweating it out.
    Be down to my speedo soon! :eek:
    :dex:
    Chvymn99, Eric VW, rdust and 2 others like this.
  8. Horkn
    That's the coffee temp.
  9. bushpilot
    bushpilot
    Eastern Washington
    Noooooooooooooooo! :hair::bug::wacky:
    Chvymn99, Eric VW, rdust and 3 others like this.
  10. Horkn
    Speedo, feed thong, whatevahhhhhh
  11. TurboDiesel
    776 degrees on the IR thermometer was right in front of the cat between the two burn indicators in the pic above
  12. TurboDiesel
    Same here. We're at 11* right now and it will drop more.
    8 pieces of ash and a cherry on top!
    Making some serious heat!
  13. HDRock
    You have a probe in the pipe now right?
  14. bushpilot
    bushpilot
    Eastern Washington
    We have been hitting negatives the last few nights, lowest was 16 below. Loving the heat, it is easy to maintain 70, which is my target. Can go significanly higher if so desired. :dex:
    Horkn, Chvymn99, Eric VW and 2 others like this.
  15. HDRock
    Ash, red oak and Shagbark hickory.
    My stove doesn't look like it is packed to the top because the rear tube is lower level than the front ones
  16. bushpilot
    bushpilot
    Eastern Washington
    Yes, I installed one. It is pretty helpful in getting the full picture as to what is going on.
  17. Horkn
    Y'all making me jealous of your heat wave.
    It never got above 5° here today. It started at -3, warmed up to 5, then was 2 at 5pm, and 0° now.
  18. Horkn
    East/ West one in there ;)
    Chvymn99, Eric VW and HDRock like this.
  19. HDRock
    My pipe hits 750-800 at start up
    Chvymn99, Eric VW and Horkn like this.
  20. HDRock
    No, E/W tonight, hot coals :fire:
