Stove Tetris
Discussion in 'Everything Else (off topic)' started by bobdog2o02, Jan 17, 2016.
  1. DaveGunter
    DaveGunter
    That sounds exactly the same for me, I'm burning spruce, I have to keep the flue temp (probe) under 750 or things will run away.
    And like DexterDay said the gap down the middle between the two splits eithe side of the dog house is crucial.
    FatBoy85, Eric VW, DexterDay and 5 others like this.
  2. bushpilot
    bushpilot
    Eastern Washington
    I did an experiment last night. I loaded it up with medium splits, pretty tight, on top of coals raked forward. Medium BTU woods - douglas fir and lodgepole. The desired gap in front of the doghouse. After it flamed up, I closed the primary air off, which kept secondary air going. And went to bed.
    This morning the missus said it was 71 when she got up, but said it was too hot in the night. There were good coals in the stove. The glass is pretty dirty, so maybe a little more primary would have helped, but house already was warmer than desired. The outside temp was in the low 20s.
    So, that was overkill for these temperatures. I don't mind the house cooling down into the mid 60s in the night. I will try this type of load again when the temps are down in the single digits.
    Buzz Benton, Horkn, Eric VW and 5 others like this.
  3. Canadian border VT
    OK I'll play.. loaded fast and not greatest cause stove was hot! really it was.. pic looks grainy but Tha t wbas bottom pieces Startin to smoke.. 20161211_150721.jpg 0
    Horkn, Eric VW, Chvymn99 and 4 others like this.
  4. papadave
    Fuul load in last night and the OAT was 16 this am, with the IAT down to 66......lots of coals. That's a little cool for this house, so I threw in another 6 small splits about 8 am.
    It's still 72 in the house at 3:30 pm, OAT is about 24.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    :thumbs:
    Leaving that gap so that the dog house blows hot air right onto the incoming section of the secondary air is why I think Englander put them both in the center (front and back). If they were in different spots? They would never reacged the emissions levels that they got out of this big stove! If burned E/W it would still burn pretty good. But not as hot and as clean as N/S with a small gap (1/2" or so).
    Horkn, papadave, Eric VW and 2 others like this.
  6. Eric VW
    So's I unnerstand this stove- it let's primary air in in front of the bottom of the door, and at the back of the firebox?
    Horkn likes this.
  7. DexterDay
    Northeast Oh
    Nope. The doghouse in the front is unregulated . As is secondary . But that doghouse air blows through the splits and hottest air hits the section where the secondary air comes in.
    Because they are both unregulated. That's why it's so efficient. Hot air blowing against the part of the stove that burns all the smoke. Makes it a super efficient stove and also males it burn so well with almost any load (N/S that is).
    Both can be manually blocked . With magnets and aluminum foil... But I'd have to post pics. Primary air only comes in as the "air wash" for the glass.
    Horkn and Eric VW like this.
  8. Eric VW
    Ok. Got it. But this "spring thingy" as it's come to be called, this rod thing.....what does it control Kenis?
    Horkn likes this.
  9. papadave
    I'm not Kenis, but that is what controls the primary intake.
  10. bushpilot
    bushpilot
    Eastern Washington
    I guess I still haven't figured out the airflow in this thing. So the rod controls the air inlets on each side of the doghouse, but the doghouse is unregulated? The secondary air, if I am not mistaken, comes up the back (where there is no firebrick), along the two sides, and through the drilled tubes?
    These guys did some thinkin' figuring how that is all going to work out right. It baffles me that so much of the airflow is unregulated, but it works out well and with good control.
  11. blacktail
    blacktail
    PNW
    I'm almost embarrassed to post this, because the two pieces on the far left are, gulp, cottonwood. The rest is birch and big leaf maple.
    FatBoy85, HDRock, Thor and 8 others like this.
  12. Eric VW
    Thanks PD, just trying to make a comparison to the eventual replacement loaner stove (a Vogelzang Performer) I have in our basement. LPAO (lower primary air orifice-a few drilled holes, similar secondary tube arrangement- both unreg'd,
    Only adjustable air is the air wash over the top of the door.....
    Thor and Horkn like this.
  13. DaveGunter
    DaveGunter
    Doghouse air is unregulated from two small holes just behind the front legs.
    Primary air is from the manifold inlet at the back of the stove, where you can hook the OAK if you want to. The manifold inlet is controlled by the rod, however it can never be completely closed.
    Secondary air is from the rectangle hole above and to the rear of the manifold, unregulated, supplies only the tubes just below the baffle board. This air passage inside of the stove is superheated in part by the blowtorch of the doghouse.
  14. bushpilot
    bushpilot
    Eastern Washington
    Well, I played Tetris again last night (sorry, I keep forgetting :ithappened:), with a very large split of douglas fir (one of my highest BTU woods), and a few normal splits of the same, plus some pine on top near the tubes, thinking it would help the secondary combustion. All this on top of a very active bed of coals, with a gap in front of the doghouse. After I had sustainable flames, I closed the air damper completely. It went to mostly secondary burn (yellow-orange-blue color), with an intermittant whisp of yellow flame rising from the bottom. And I went to bed. From the bedroom I could hear that the stove temp was going up.
    This morning I woke to a good bed of coals, a fairly clean glass, a warm-hot stove and the house at 68 degrees, with the outside temp at 0 degrees. When I asked the missus if the house ever seemed too warm in the night, she said no, it worked for her.
    This is good sucess, I wasn't able to manage my heat so well with the old Allnighter. Part of that is probably that I can now see exactly what is going on in the stove through the glass door, and I couldn't do that with the Allnighter.
    Tonight will be colder (-4 they say), I'll try a simlar burn. I have another chunk of douglar fir set aside already.
    Eric VW, HDRock, Horkn and 5 others like this.
  15. DexterDay
    Northeast Oh
    The Primary for 30 comes in just at the top of the door as well. It is the only controlled air. The doghouse comes in from 2 small holes at the bottom/front of the stove and secondary air is back by the primary, but just an open square/rectangle.
    So the 2 airways that are unregulated are what keeps this machine so efficient. The doghouse air is directed straight back at the incoming secondary air (so long as you have a gap between the splits at the doghouse). You just control the speed and heat at which it burns with the primary.
    Chvymn99, Thor, Eric VW and 1 other person like this.
  16. DexterDay
    Northeast Oh
    Just read this after I posted.
    Yep.. Another reason I should read all posts before typing a small bible! :thumbs:
    Well said Dave!
    DaveGunter, Chvymn99, Thor and 2 others like this.
  17. Horkn
    Huge bed of hot freaking coals wouldn't allow me to stack tighter or more. But here is all beech with an ironwood piece on the top center. IMG_20161213_192110575.jpg
  18. rdust
    rdust
    SE, Michigan
    Already in the low teens, will probably touch single digits tonight.
  19. bushpilot
    bushpilot
    Eastern Washington
    OK, I see that, I didn't get it until now! (yeah, I am slow)
    Does any air enter from under the lip on each side of the doghouse? I have reached under that lip and thought I felt an opening, which I assumed was connected to either the primary or the doghouse.
    Horkn likes this.
  20. Horkn
    Thor, concretegrazer, HDRock and 2 others like this.
