Stove pipe
Discussion in 'Modern EPA Stoves and Fireplaces' started by Keweenaw, Feb 1, 2016.
  1. papadave
    Generally, you can double the outside temp of single wall pipe to get an estimate what the exhaust gas temps are.
    I have no idea how to figure out how to do that from the outside of double wall.
  2. HDRock
    X2
    double wall pipe you need a (Condar ls a brand name) probe thermometer, so you can monitor your pipe temperature and keep the pipe hot enough to prevent accumulating creosote, a condar stovetop thermometer to monitor your stove top temperatures so you know where you're at and you know you are not over firing it.
    What you worry about is getting your Pipe hot enough, but not too hot, and getting the heat out of your stove that you want and burning clean without over firing,
    best way to find out if you're burning clean is to go outside and see if you're creating smoke.
    After all that you can worry about burn times
  3. Keweenaw
    Keweenaw
    tapiola mi
    That sounds like the smart thing to do, do you know a good bang for your buck thermometer that you would recommend ?
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Like HDRock said above Condar. Spend the $ once, it's good stuff. Buy two, one for the pipe, one for the stove. I can send links tomorrow when I'm at the PC.
  5. HDRock
    Rutland thermometers are totally crap I had five of them
  6. papadave
    Keweenaw , it just occurred to me that I got a probe thermo for my pipe, but for reasons I won't go into, I can't install.
    If you'd like it, pm your addy, and I'll stick in the mail.
    It's a Condar Fluegard.
  7. Keweenaw
    Keweenaw
    tapiola mi
    I will check those out and probably order a set up :thumbs:
    Backwoods Savage and Eric VW like this.
  8. Eric VW
    I've got a roll of 2600F Ceramic Fiber Blanket if you need a piece.... 1/2" thick, 6# as it's called. It's 24" wide, so a length measurement is all you'd need.
  9. HDRock
    As far as the key damper is concerned if it is in there it will only reduce your draft slightly, as long as it is full open
  10. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    As long as the pipe comes apart easily I'd leave it out for now. Can always put it in if you need it.
  11. HDRock
    There you go man, the brothers are going to hook you up, now all you need now is a stovetop thermometer:thumbs:
    Kudos, guys :salute:
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    And the thermo on the pipe now will be ok enough for the stove top until a new one can be ordered.
    I love this place, way to be Eric VW and papadave for stepping up.
  13. Eric VW
    Hey I know who to call on if I need to shoot tater tots athi velocity into the oven:thumbs:
    Backwoods Savage and bobdog2o02 like this.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Now that's an idea, a tot-gun.
    papadave and Eric VW like this.
  15. HDRock
    yeah it will give you a general idea even if it is off one, two or three hundred degrees, but won't really tell you anything stuck on a double wall pipe
    saskwoodburner and Eric VW like this.
  16. Brad38
    Brad38
    S. Indiana
    Awesome place for sure...
  17. Eric VW
    I just thought to myself today...."Where the heck is @Brad38?":thumbs:
    I really did, bud!:yes:
  18. papadave
    Once he gets this Condar, just take the one on the pipe and put it on the stove.
    The mags are pretty slow to respond to temp changes, but will do fine. Get an IR.
    HDRock, Eric VW and bobdog2o02 like this.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'd say run the mag on the stove now. ...
  20. papadave
    Yep, another fine option and gooder than mine.:headbang:
    Brad38, HDRock and Eric VW like this.
