Stove & Heating Set Ups
Discussion in 'The Wood Pile' started by Mirkwood Jim, Dec 2, 2015.
  1. Rowerwet
    Rowerwet
    Seacoast NH/MA
    4-6 cords/ year. I'm the caretaker/pastor, the plastic on the windows makes the biggest difference. Adding a ceiling fan to the stove room made the next biggest.
    I'd like to insulate better, but due to money, I get to do more repairs to stuff that was ignored/hacked than real progress. This past spring I replaced the main sewer pipes, the old duct tape just couldn't stop the rotten cast iron from collapsing. (I found the leak when a drain backed up)
    Some projects make me want to renovate with matches...
  2. Rowerwet
    Rowerwet
    Seacoast NH/MA
    4-6 cords/ year, we keep it at 60 at night and 64 during the day. I'm the caretaker/pastor so all expenses are paid by the Church. I scrounge the wood to save the church money.
    The plastic on the windows makes the biggest difference. Adding a ceiling fan to the stove room made the next biggest.
    I'd like to insulate better, but due to money, I get to do more repairs to stuff that was ignored/hacked than real progress. This past spring I replaced the main sewer pipes, the old duct tape just couldn't stop the rotten cast iron from collapsing. (I found the leak when a drain backed up) project took a week, with no water in the house..
  3. Canadian border VT
    here's mine
    Stove Woodstock Ideal Steel up to 60,000 BTUs an hour
    location corner install 2nd floor... house is contemporary split level 5 story double stairway 18 foot ceilings
    house is 2800 square feet with high ceiling cubic feet is way high
    supplemental heat buderus 100,000 BTUS basement oil hot water
    outside Temps 30 to 40 below when cold 0 is common
    stove room is 80 rest of house 7os
    insulation average r 20 wall r 40 ceilings house faces southwest lots of solar gain and light
    sits on 22 acres
    Woodsnwoods, Horkn, Eric VW and 5 others like this.
  4. Huntindog1
    Huntindog1
    South Central Indiana
    I heat around 2600 sq ft brick ranch style house from the basement with a 3.2 cu ft Myriad stove. I have a very well insulated house and energy efficient windows.
    Stove heat comes up thru the wood floors and a couple vents in the floor just from natural convection.
    The stove can keep the center of the house main floor in the low 70's by morning day light and the outer ends of the house will be 67-68 in the mornings if you leave the bed room doors open as I tell my kids.
    I dont use any blowers or fans radiant heat works best in my setup.
    Woodsnwoods, Horkn, Eric VW and 4 others like this.
  5. Huntindog1
    Huntindog1
    Dont know if you remember but over the summer I took out all my firebrick and put 1/4" ceramic insulation behind them and under them plus add the new row of bricks on top of the first row.
  6. Mirkwood Jim
    Mirkwood Jim
    Devon, England
    80K BTU sounds like a beast (and like you need that output!)
    Culmstock is about 10miles (ironically miles is still the most used unit of distance-go figure!) so very close by :)
  7. bushpilot
    bushpilot
    Eastern Washington
    :wacky:Huh?! :wacky:
  8. wildwest
    I thought he only had a pellet stove:)
  9. Mirkwood Jim
    Mirkwood Jim
    Devon, England
    :picard::picard::picard:
    Was this question directed at me or Gary? Ignore this, I had' tread the posts below
  10. Brad38
    Brad38
    S. Indiana
    Mine
    Stove: Woodstock Ideal Steel
    Stove Location: our 500 sq ft garage we converted to a family room this year. (1st time wood-burner) Stove is not centrally located, so I use a box fan or two to blow cooler air into the family room. We have a 36" door that goes to the back bedrooms, and we had the contactor cut a 5 x 7 opening in the garage wall into our existing living room.
    Total Approx House Area: 2,350 sq ft ranch on a concrete slab built in 2001.
    Stove Room Temp (Assuming External temp of 40 F): usually around 80 lol.
    Extremity of House temp: this would be our master bathroom. Probably around 70 when the outside temp is 40.
    Supplementary Heating: forced-air heat pump with bottled propane back-up that kicks on once the temp drops below 30 outside.
    House Insulation: Whatever r-value 2x4 wall studs have (r-12?) and pretty thick blown-in insulation for the attic. Our windows are the builder-grade double-pane vinyl Windows. This is where we have opportunities for efficiency.
    Pic from this am. Toasty warm!
  11. Canadian border VT
    Brad38 every single time I see that pic I get jealous:eek: it's looks so nice...
  12. Brad38
    Brad38
    S. Indiana
    Thanks! No need for jealousy, lol. You have a great set up yourself! If I remember correctly, you had that great covered bridge art.
  13. wildwest
    sorry Jim, it was infact directed at Gary:)
  14. Canadian border VT
    oh yeah I want to re-do the corner hearth and run river stone up behind it. I love all IS pic and most every stove your hearth and wall and placement and color Coordination are just:yes:
    Woodsnwoods, Eric VW, Brad38 and 2 others like this.
  15. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Have had the OWB for about 9 years now, just put in the pellet burner last year. I cut some wood when they let me run a chainsaw:D buy a little and I have a buddy that cuts me 2-3 cord a year just for something to do.
    Gary
  16. Backwoods Savage
    No doubt that cement slab also has much to do with it Dave.
    Woodsnwoods, Horkn, Eric VW and 3 others like this.
  17. Brad38
    Brad38
    S. Indiana
    That would look good!
  18. papadave
    Woodsnwoods, Horkn, Eric VW and 2 others like this.
  19. bushpilot
    bushpilot
    Eastern Washington
    Almost comprehensible now that we have context. Almost. :sherlock:
  20. wildwest
    :rofl: :lol::rofl: :lol::picard::rofl: :lol::rofl: :lol::rofl: :lol:
    papadave, Woodsnwoods and Horkn like this.
