Stop switch malfunction, Husq
Discussion in 'Chainsaws and Power Equipment' started by Sirchopsalot, Oct 15, 2022.
  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Cutting away at the Long awaited Ash score today, I went to shut the saw down, and the stop switch didnt shut the saw down!
    It was running funny, as it does when its out of fuel. I was thinking I'd just bury the bar in the log I was cutting and stall it out, when it starved out first.
    It has the cylinder pressure release button, so that would have been next in line.
    I took the covers off, expecting to see a busted wire somewhere, to discover the stop switch contact bit was well fouled with fine saw dust powder.
    A simple scrape-out with a tool remedied that....she started and stut down per my wishes.
    Something to check now and again I reckon.
    I also found bits of noodle shreds tucked into the cooling fins, explaining the pleasant woodsmoke every time I shut down for a refuel.
    Issues addressed.
    Sca
    Chris F, Jutt, Screwloose and 5 others like this.
  2. chris
    chris
    SE WI
    A cylinder base gasket leak will cause the same problem- sneaky as he double tooth piks - don't ask how I know.
  3. The Wood Wolverine
    If something similar happens to me I flip the choke on, which always stalls the saw out.
  4. Screwloose
    Screwloose
    Compressed air is your friend.
  5. Sirchopsalot
    Sirchopsalot
    medium city in CT
    As is a little tlc once in a while.
    Screwloose likes this.
