Stock 362c-m VS Mastermind 362c-m (video)
Discussion in 'Chainsaws and Power Equipment' started by Machria, Nov 29, 2015.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    Waiting for my 046 to return from MM. :)
    Eric VW, Chvymn99 and MasterMech like this.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Very nice gains!! Congrats! That thing runs great!!
    Eric VW, Chvymn99 and Moparmyway like this.
  3. Moparmyway
    Moparmyway
    New York
    Now we have to teach him how to pull a cookie under his cut so he can keep his chain out of the dirt ! :doh:
  4. XXL
    XXL
    Ontario, Canada
    Wow! Very impressive numbers. Great looking saw and bar setup. Good looking pants too;)
  5. DexterDay
    Northeast Oh
    So true...
    I learned that trick from guys on this site... I used to be a dirt cutter :(
    We all start somewhere :D
  6. Elderthewelder
    Elderthewelder
    Washington State
    good to know it can handle a 28" if i ever need it. (I have same saw)
    Eric VW likes this.
  7. Moparmyway
    Moparmyway
    New York
    Shoot ................ I still cut dirt sometimes, but I usually dont cut cookies
    Good thing I got a few files laying around
  8. Jon_E
    Jon_E
    Southwestern Vermont
    I would imagine that a 20" bar, an 8-pin or even 9-pin sprocket, a razor sharp chain and WOT at the start of the cut will shave another 4-6 seconds off those times.
    Eric VW likes this.
  9. MasterMech
    A steady hand too. Machria has a lot of rockin' and rollin' happening there and at times it looked like he had the dawgs hooked.
    Absolutely no doubt that that machine was making a lot more power tho, which I think was the point he was trying to make. :)
  10. Machria
    Machria
    Long Island, NY
    You got it. And I did get the dog caught up pretty good in that one cut. Those big dawgs are really nice sometimes when you need the leverage, but they can also get in the way at times. I'm sure with more experience I'll learn to use them better...
    Oh, I cut about as much dirt as I do wood sometimes!! Why do you guys think I spend so much time in the "sharpening" threads?? ;)
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Going out on a limb and say a 8T 9T 3/8 rim in 20" wood only slow this saw down IMO. I would keep it a 7T unless I was limbing and wanted more chain speed. JMO
  12. Machria
    Machria
    Long Island, NY
    8T, 9T? Huh? Educate a dude.....
    Eric VW and clemsonfor like this.
  13. Machria
    Machria
    Long Island, NY
    I found the 25" bar with full skip chain cut much better and faster than the 20" bar with regular chain (both RS) on this saw.
  14. SquareFile
    SquareFile
    somewhere
    I bout shat myself reading that recommendation of 8t or 9t. :eek:
  15. clemsonfor
    The number or driver link holes on the rim sprocket. The bigger the sprocket the higher the chain speed. Just not as much torque
    Eric VW likes this.
  16. Machria
    Machria
    Long Island, NY
    Interesting....
    Eric VW likes this.
  17. Moparmyway
    Moparmyway
    New York
    It is interesting indeed, however that 7 tooth driver you are running now is what I would stick with.
    If you get a ported 70cc saw, then I would suggest trying an 8 tooth.
  18. Jon_E
    Jon_E
    Ok educate me here. Don't know as much as I thought I did. I have a bone stock MS 361. Running 8T and a 16 inch bar with 72LGX chain. I'm going to get more chain speed than with a 7T sprocket. How much torque am I losing? I feel that the sharpness of the chain makes a far greater impact on the cutting speed than the sprocket.
    FWIW I run a 24" bar with 72LGX with the 7T sprocket and it's a dog unless it's razor sharp.
    Eric VW likes this.
  19. MasterMech
    The engine speed will pretty much adjust to the sprocket. Run a small sprocket, higher rpms and the saw will be harder to stall in the cut for sure. Run a larger sprocket, engine RPMs will drop accordingly for the same load and the saw will stall easier.
    I prefer the torquey feel of the smaller sprocket when working in the woods bucking up trunks. It is fun to experiment with bigger sprockets tho. I bet your 60/16/8 combo makes taking apart the tops of downed trees fun. Zip, zip, zip!
    Eric VW likes this.
  20. Jon_E
    Jon_E
    Oh yeah it's a hot knife through butter on anything under 6" or so.
    Eric VW and MasterMech like this.
