Stihl's 4 mix engine?
Discussion in 'Chainsaws and Power Equipment' started by Marshel54, Jul 13, 2017.
  1. Kg461
    Kg461
    Provencal, La.
    I agree. Ive had my BR 600 10yrs now and I disassembled it, cleaned valves, installed new rings and bottomseals, and a new plastic cam gear. I keep a regular check on the valve adjustment and run Red Armor @ 40:1 and not as much as a single glitch since
    cus_deluxe likes this.
  2. RCBS
    RCBS
    Over here
    IMO extra torque is about all the 4-mix has to offer. Have used a friends trimmer before...do not know the model #. It was a little cantankerous to get started, but ran fine after. The main issue I had was that the trimmer weighs 3 pounds more than what I'm used to. That's quite a bit of weight for the extra .25hp it produces. My friend has told me although he has been satisfied with the trimmer (think he's had it for 4-5 years), he wouldn't buy one again. I do not believe he has had any reliability issues with it. He doesn't like the weight either. He trims around probably 60 trees, a 200' long, 6' bank along road edge and several out buildings spread over 4+ acres. Weight becomes significant when dealing with that much trimming.
    Hammy, Kg461 and clemsonfor like this.
  3. Kg461
    Kg461
    Provencal, La.
    1. I have been inside a fs 4 mix motor vs a simple fs250 . Less moving parts, no plastics internally is what a fs250 has compared to fs 4 mix motor
    Hammy and RCBS like this.
  4. clemsonfor
    Plastic cam gear:eek:. Why not brass , aluminum or some other soft metal? Cost I guess, save the $2
    Hammy, RCBS and Kg461 like this.
  5. Kg461
    Kg461
    Provencal, La.
    They really do hold up well though to be plastic and pretty simple to change.
  6. Kg461
    Kg461
    Provencal, La.
    porsche965, Hammy, RCBS and 1 other person like this.
  7. RCBS
    RCBS
    Over here
    Cost and weight savings.
    Hammy and Kg461 like this.
  8. MasterMech
    The 600s blow when the blower tubes get all discombobulated and the airflow from the blower is incorrect. Some guys run the nozzle way down actually on the ground allowing them to overrev big time. They aren't bulletproof but properly cared for they will hold up.
    Granted my BR6 only does my lawn for the most part. But it's lighter, quieter, more comfortable, and drinks a helluva lot less fuel than the equivalent or bigger RedMax/Husky blowers. Works for me. (And yes, I have one of the first year production BR6s that were especially problematic.
    clemsonfor and cus_deluxe like this.
  9. MasterMech
    Metal is not always superior. Many plastics now exceed the strength of cast aluminum/mag/zinc parts. Now that cam gear would likely be a sintered powered metal part if it were made from something metallic and that presents its own problems with complex shapes.
    Horkn, cus_deluxe and 94BULLITT like this.
  10. clemsonfor
    Yea it looks durable for its application I guess. Heck first thing I thought of was automotive. Wasent it some GM from the 70s or 80s Mabe 90s??? Had nylon cam gears.
    94BULLITT likes this.
  11. OldJack
    OldJack
    Saskatchewan, Canada
  12. MasterMech
    Plenty of them did. The Mark IV big blocks from the 80's with finned timing chain sprockets were the ones notorious for failing. Gen V ('91+) went to a different style sprocket, metal hubs, solid nylon sprocket teeth which didn't have problems like the older engines.
  13. clemsonfor
    i think these were the ones i was thinking of. i just remember it was older cars of a certain vintage when i worked at the parts store
