Stihl Yellow Bar vs Green Bar
Discussion in 'Chainsaws and Power Equipment' started by Woodchuck, Apr 8, 2015.
  1. Machria
    Machria
    Long Island, NY
    Thanks... Ordered a 28" light bar and a full skip chain for it, will be a nice setup along with my soon to be MM'd 362 for those few times I run into a big boy I normally pass up cause they are too big.
    Elderthewelder and clemsonfor like this.
  2. clemsonfor
    Those big boys make you work for the splits unless just a perfect red oak or other easy splitting wood
    Elderthewelder likes this.
  3. Elderthewelder
    Elderthewelder
    Washington State
    28" is alot of bar and chain for the 362, but I personally think after Randy gets done with it that it well pull it, I would however recommend having Randy put the High Output oiler pump guts in the oiler while he has it torn apart, it well oil that 28 inch bar much better than the stock oiler
    you can order them through the dealer, was around $40 or so when I got mine a few months ago. they had to order them but they came in within a week
    part numbers
    1128 647 0602 pump piston
    1128 647 4803 control bolt
    FarmHand78, MasterMech and clemsonfor like this.
  4. clemsonfor
    Yea your gonna want a high output liked on that!!!
    Running a 25 and 32" bar on the 650 I wish I had a high output oiler. The stock one sure seems on the stingy side.
  5. Glockem45
    Glockem45
    Annandale, Virginia
    So, does this mean on my MS290 with 20" bar that came with a green chain, that I cannot install a yellow chain on the stock bar? I assume my stock bar is a green bar?
  6. haveissues
    haveissues
    Hudson Valley
    You can use any chain as long as it is the correct pitch and gauge. It doesn't matter if it is a low kickback chain or not. That being said, you probably won't notice a difference cutting with a yellow or green chain unless you are bore cutting with the tip.
    Horkn and clemsonfor like this.
  7. clemsonfor
    Yep you can run green chain , yellow chain, husky chain (oregon), oregon chain, carlton or whatever. You dont have to just run still green on green bar
  8. Boog
    Boog
    Where my spirit is free
    That's because they were my handmedowns!
    clemsonfor likes this.
  9. Horkn
    I just got a loop of stihl rs yellow for my 16" 029 super.
    I'll try it out tomorrow. I've got a bunch of rounds to make and haul. I'll hoping it saves me some time and effort.
    94BULLITT likes this.
