Stihl vs Husqvarna...
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Sep 20, 2023.
  1. Eggshooterist
    Eggshooterist
    Erff
    AND oil mixed in the gas vs the factory oil injection.
  2. Eggshooterist
    Eggshooterist
    Erff
    You guys should have seen the inside of that Homelite. That wonderful flap of felt for a filter is about as useless a screen door on a submarine. I thought it was rust inside all over the bearngs ect. I almost tossed the thing in the hopper but, because I already spent money on the seals and gaskets, I investigated. All that "rust" was sawdust fines and earl on everything. Easily wiped off or rinsed out.
  3. Sawdust Man
    Sawdust Man
    Snob....:whistle:
    Air filters, AND mix oil....good grief....what a legalist.....
    :picard:
  4. Eggshooterist
    Eggshooterist
    Erff
  5. Eggshooterist
    Eggshooterist
    Erff
    Its about to be on for the 543 xp hoover...
  6. Eggshooterist
    Eggshooterist
    Erff
    Between fall yard maintenance, camper winterizing and building a hunting shack with a composting toilet in the corner, I had some time to get this far on the 543. IMG_20231027_163254984~2.jpg IMG_20231027_163139051~2.jpg IMG_20231027_163638303~2.jpg IMG_20231027_160916860~2.jpg IMG_20231027_163129281~2.jpg IMG_20231027_163649460~2.jpg
    The plan is to use my air pencil grinder to cut out the aluminum to the scribe line and JB weld the stack to the factory filter mount. It will slip over the diameter and set on that shelf. The nylock nut will be there as well. I've done this before on another saw and it works perfectly. I figured if a porters use the JB in the intake on a cylinder, its good enough to seal these together. Like the Makita, the filter will hold the hood on.
  7. Ohio
    Not Ohio
    V stack and saw mods eh. * FHC heavy breathing intensifies*
  8. Eggshooterist
    Eggshooterist
    Erff
    Gotta stop the suck. Its a saw not a vacuum cleaner. :rofl: :lol:Any additional performance is a bonus. It won't be the first saw Kevin has done of mine that I've already did "stuff" too.
  9. Eggshooterist
    Eggshooterist
    Erff
    Morning peeps. Sorry this is going so slow. I had other "catastrophes" to deal with. Anyway, stack is JB welded in place. Not sure why I thought I could use that stud to place a nut on as I stated. :loco: :crazy: I'll try to get this mounted up this coming week and start the filter cover modding. The nice thing is its not expensive to return to stock. The elbow is $8 and cover is $15. If they were to offer a better factory filter I'd probably change it back because it looks nice stock. Looks matter to the logs your cutting...:rofl: :lol:
  10. Eggshooterist
    Eggshooterist
    Erff
    Done. But first....I didn't realize the factory filter is two pieces. There is definitely evidence of that seam leaking fines. Id grease that seam for those running the factory filter.
    IMG_20231104_135920652~2.jpg IMG_20231104_135826657~2.jpg IMG_20231104_135751146~2.jpg IMG_20231104_135804125~2.jpg
  11. Eggshooterist
    Eggshooterist
    Erff
  12. ammoaddict
    ammoaddict
    Granite Falls, NC
    I contacted them a while back, they said they had no plans to bring it to USA.
    Buttermilk likes this.
  13. Eggshooterist
    Eggshooterist
    Erff
    Same response I got.
  14. buzz-saw
    buzz-saw
    Ct.
  15. Eggshooterist
    Eggshooterist
    Erff
    I've put there stacks and filters on 4 saws now and a Honda powered mantis mini tiller. Lol
    Buttermilk and Sawdust Man like this.
  16. Sawdust Man
    Sawdust Man
    The redmax killed trees today.
    I'm really liking this little bugger.
    Probably has 20-30 tanks of fuel through it now.
    IMG_20231104_163136.jpg IMG_20231104_155504.jpg IMG_20231104_150244.jpg IMG_20231104_144323.jpg IMG_20231104_125151.jpg IMG_20231104_112231.jpg
  17. Eggshooterist
    Eggshooterist
    Erff
    Mrxlh, Buttermilk and Sawdust Man like this.
  18. Buttermilk
    Buttermilk
    Central AR
    I know it's not the saws yall are comparing but I recently got my XS 4910. Has become my go to saw. Can't believe what that thing will cut.
    Stephiedoll, Mrxlh, Barcroftb and 3 others like this.
  19. jmb6420
    jmb6420
    Grand lake, Oklahoma
  20. Eggshooterist
    Eggshooterist
    Erff
    Those are nice saws too. You can do a lot of fire wood cutting with a quality 40-50cc saw. I've said it before, my Dad used a Stihl 031AV with a 16" hard nose bar to keep us and another household warm for many years.
