Stihl MS390 versus MS360, Worth Fixing the 390 up?
Discussion in 'Chainsaws and Power Equipment' started by Boog, Nov 18, 2015.
  1. SquareFile
    SquareFile
    somewhere
    Line boring the halves would be simpler than your 2pc idea. How would you bolt the head down?
    94BULLITT likes this.
  2. MasterMech
    True. I was joking about the 2pc.
    Somewhere I have a few junk 1127 cylinders. I have the strange urge to take a hacksaw to one now, lol.
    clemsonfor likes this.
  3. Boog
    Boog
    Where my spirit is free
    I was sort of thinking of the opposite of the quarter ....................... drill and tap a hole in the top of the cylinder (sort of like a decomp valve hole), run an appropriately sized bolt up through it so the head of the bolt "replaces the quarter", lock it down with a nut on top! That ought to work! :whistle:
  4. clemsonfor
    What about the wrist pin? It would be off center. Is there clearance to the head off center?
    Boog likes this.
  5. Boog
    Boog
    I was talking about the top of the cylinder, not the piston ...................... but that would work too if it could clear the pin/bearing/rod top. Gee, I should have tried that on this old 460 piston I crushed with a stop tool! :rofl: :lol:
    clemsonfor and ja_cain like this.
  6. 94BULLITT
    94BULLITT
    Frederick County, VA
    A bolt will cause hot spots, which will cause detnation.
    Boog and clemsonfor like this.
  7. Hedgerow
    Hedgerow
    SW Missouri
    The 039 I built for the clamshell build off had a welded popup in it..
    Not the best way to go.
    And only netted about 10 pounds of comp. Not worth the trouble.
    Should have used a taller piston and cut it to suit.
    Boog and MasterMech like this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    They add weight to the piston.
    Boog likes this.
  9. clemsonfor
    I was also thinking a taller piston out of something as well and cut to chamber.
    Boog likes this.
  10. Hedgerow
    Hedgerow
    SW Missouri
    All in all, piston work on these is not the best bang for buck or time that I've seen.
    Getting a good set of port timing #'s and good ole fashion shapes are what they really respond to.
    "Make em a better pump"...
  11. MasterMech
    Hmm. Interestingly enough, a quick search of Husky and Stihl Spec charts show the only other 49mm saws in recent memory being the 570 and the 460 Rancher. Or the TS400. Everything newer is a Strato and I don't think that would work out in an open port jug.
    Pickin's could be slim for donor slugs.
    Boog likes this.
  12. Boog
    Boog
    My $33 Chinese parts kit received as advertised, that's a Zama carb too. It took 15 days to get here, a few more than normal, but I saw that shipping went from Chicago to somewhere in MO, then to Cleveland, then to me, a round-about US route.
  13. clemsonfor
    I got my huztle bran DP muffler I ordered in like 7 days!
    Boog likes this.
  14. Boog
    Boog
    Hmmmm ...................
    HYWAY PISTON / RINGS KIT AFTERMARKET Fits STIHL TS400 TS 400 (H31400)
    HUSQVARNA 460 RANCHER CHAINSAW PISTON (49mm)
    This looks sort of tall: Wiseco Honda CR80 CR80R CR 80 80R Piston Kit 49mm 1986-2002
    Never seen rings like on this one!!! Piston Kit with Pin Rings Clip Set For YAMAHA XC125 XV250 STD Standard Bore 49mm :thumbs:
  15. DexterDay
    DexterDay Administrator
    Northeast Oh
    Boog likes this.
  16. Hedgerow
    Hedgerow
    SW Missouri
    The TS400 would work, but again, not sure the gains in comp would be worth the time and expense. May be ahead to spent the time and effort on carb work and port timing for gains.
  17. Boog
    Boog
    The save-a-thread I ordered came in today so I proceeded to tap out the plug hole on the cylinder. That went perfect. I had cleaned the exterior of the cylinder yesterday, but was waiting until I tapped it to de-carb the top of the head. I started to clean up the carbon with a brass wire brush on my dremel wand and noticed what appears to be a crack on the curved edge of the "head" opposite the spark plug hole. I "painted" it in red. Does not look like a casting imperfection or defect to me, it looks like a crack!
    What do you guys think?
  18. clemsonfor
    Sure kooks like it could be a crack to me? But on the phone and a pic its hard to say. Be odd I think for a casting flaw. But I am no metal expert either.
    Boog likes this.
  19. lukem
    Looks like a casting flaw. The reason I say that is because the edges are rounded/smooth. If it is a crack it's been there for a while. I guess you could have smoothed the edges cleaning up the carbon...but probably not that uniformly.
    DexterDay, Boog and SquareFile like this.
  20. SquareFile
    SquareFile
    somewhere
    I'd say your correct. The flaw or term is called cold lap.
