Stihl MS390 versus MS360, Worth Fixing the 390 up?
Discussion in 'Chainsaws and Power Equipment' started by Boog, Nov 18, 2015.
  1. clemsonfor
    I would have too look at mine. But I too think you have to pull the whole handle off the saw, which is not an easy task on those. But I do not remember seeing stihl or mahle cast anywhere thats visible on mine either???
    94BULLITT likes this.
  2. MasterMech
    I think he was being a bit facetious. ;) His English is good enough, just not his first language.
    pantelis and clemsonfor like this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    That is basically what this guy is saying. I looked at some cylinders on ebay and they have Stihl and Mahle cast in them. I'm thinking I may be able to take a screwdriver and feel the "stihl" cast in the cylinder. If not I guess I'll have go by the looks if the cylinder.
    Stihl Chainsaw 029 MS290 Mahle Cylinder Top End MS 290 Farm Boss 029 Super
    pantelis likes this.
  4. clemsonfor
    Ok after seeing where it is. I am pretty sure there would be no way to see that with the handle on? Maybe I am wrong? But I have never tried to look for mine as I bought it new and its never been at a shop so no way its been swapped. I have had the saw totally apart though..just didnt look for the castings.
    pantelis and 94BULLITT like this.
  5. Hedgerow
    Hedgerow
    SW Missouri
    File half the thickness of the key.
    On some builds, the key is removed. It's for location, not to hold the flywheel on. clean and dry surfaces only. Taper fit.
    A couple raps with the cordless impact sets it better than anything else I've used.
    The factory timing advance is quite mild on the 1127 and 1123 series saws. Levi's 025 has been advanced 10 degrees and still no issues.
    That little thing puts out as much power as just about anything else in it's size class. Sans a really hot 346 OE.
  6. Mag Craft
    Mag Craft
    South East Wyoming
    Gotcha, No worrys.
  7. 94BULLITT
    94BULLITT
    I've got a 250 I've been wanting to play with with. I'll have to keep the 10* in mind. I think the non pro saws are really detuned and there are some big gains to be made easily.
    clemsonfor likes this.
  8. Hedgerow
    Hedgerow
    SW Missouri
  9. Hedgerow
    Hedgerow
    SW Missouri
    I would be really curious to know what the port timing #'s are in a 250 as opposed to the old edition 025.
    MasterMech and clemsonfor like this.
  10. pantelis
    pantelis
    Europe
    No i have a better method , i turn the flywheel like a casino rulette when it stop i welded to the crankshaft , perfect every time :rofl: :lol::rofl: :lol::rofl: :lol:
    MasterMech likes this.
  11. pantelis
    pantelis
    Europe
    Why most of peoples believe everything that see to tv ??????
  12. pantelis
    pantelis
    Europe
    dont worry all the china ebay carbs that i have buy writte zama and for ms 180 writte and stihl also sometimes can not understand them , theese shorts make good copies sometimes
  13. pantelis
    pantelis
    Europe
    As the statistics tell not me this F35 is round and long turd together , have loose many times from other older models anyway
  14. clemsonfor
    But as the only super power with a real air force, we are still unmatched. We have spent billions on that project though!!
    Thank you to all that wear the uniform, my brother in law included!!
    Boog and Mag Craft like this.
  15. Boog
    Boog
    Where my spirit is free
    You would need to remove the 4 hex screws holding the starter cover and look underneath. If you turn the flywheel so fins are on top you can just see the "Stihl" on the cylinder on mine.
    pantelis, 94BULLITT and MasterMech like this.
  16. 94BULLITT
    94BULLITT
    Thanks so much, I'm supposed to go tomorrow to look at it. I'll take my battery impact and bits
    Boog likes this.
  17. pantelis
    pantelis
    Europe
    Goverments many times spent millions on bull....... projects , some peoples must eat with golds spoons , for sure not me and you
  18. Boog
    Boog
    Well, that settles it. Lines have been drawn in the sand. We have the 360 and 440 here to test against it so what the heck! Details to follow! :thumbs:
  19. 94BULLITT
    94BULLITT
    It will probably be a long time before I get into mine that deep.
  20. ja_cain
    ja_cain
    Chesterfield, VA
    Might have to try advancing the timing.
    Here is my 036. I have a feeling the 039 is going to beat it though. Still need to replace the impulse line then she's ready.
    Boog likes this.
