Stihl MS390 versus MS360, Worth Fixing the 390 up?
Discussion in 'Chainsaws and Power Equipment' started by Boog, Nov 18, 2015.
  1. lukem
    Put a MAGNUM sticker on it. Adds 2 HP.
  2. ja_cain
    ja_cain
    Chesterfield, VA
    I have an 036 that I just replaced the crank seals and rebuilt the carb. I need to replace the impulse line and I will take some videos of the two. Should be interesting.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    I did that to my 170. It helped a considerable amount.
    unclefess and lukem like this.
  4. clemsonfor
    Put an XP sticker and watch the double takes :) DexterDay
    unclefess and Oldman47 like this.
  5. Hedgerow
    Hedgerow
    SW Missouri
    M Mod / Timing advance
  6. clemsonfor
    Is the timing easy to describe? Do you pull the flywheel and key and just locktite it down? How much do u rotate?
  7. 94BULLITT
    94BULLITT
    You file the key. You just have to know how much to file. Some saws have a key cast in the flywheel so it is harder to do.
    clemsonfor likes this.
  8. Mag Craft
    Mag Craft
    South East Wyoming
    You rotate the flywheel CCW.
  9. Mag Craft
    Mag Craft
    South East Wyoming
    It is hard to say how much advance your getting without using a degree wheel, but I would not go more then about 1/3 the width of the flywheel key. You could start with 1/4 if you want to be cautious.
  10. 94BULLITT
    94BULLITT
    Post 22 on give a formula so you don't have to use a degree wheel.
    timing advance?
    You can also use a timing light and that would tell you your total advance.
  11. Mag Craft
    Mag Craft
    South East Wyoming
    Please explain the timing light thing I am interested.
  12. 94BULLITT
    94BULLITT
    Here is a video
    Mag Craft likes this.
  13. Mag Craft
    Mag Craft
    South East Wyoming
    Ok still has to break out with the degree wheel. It probably would take more time than I am willing to do but if you wanted to know the total advance of the ignition it would definitely work. Thanks for showing.
    94BULLITT likes this.
  14. pantelis
    pantelis
    Europe
    DONT COMPARE
    360 pro series 390 lego toys
    concretegrazer likes this.
  15. pantelis
    pantelis
    Europe
    in my country little cheaper than a ms 362
  16. pantelis
    pantelis
    Europe
    until you destroy it
  17. 94BULLITT
    94BULLITT
    Boog I'm thinking about buying a 390. I wanna make sure it has the OEM cylinder but the guy says he can't see Stihl cast on the cylinder. He says you would have to tear then saw apart to see it. Can you easily see the Stihl or Mahle casting on yours?
    Boog likes this.
  18. Mag Craft
    Mag Craft
    South East Wyoming
    I don't get it.
  19. MasterMech
    Push her till she blows!
  20. Mag Craft
    Mag Craft
    South East Wyoming
    Ok but why would you do that to a perfectly good saw. What ever.
    pantelis and clemsonfor like this.
