Stihl MS241 build
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Feb 12, 2024.
  1. Eggshooterist
    Eggshooterist
    Erff
    Chains...
    18" Stihl 23RS .050 / .325. Narrow kerf.
    18" Stihl RS .063 standard .325
    Chud and brenndatomu like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Now, there is a noticable weight difference between these saws that the bar and chain differences doesn't explain. I've heard the earlier 241s were heavier than the later. The black unit is older than the XS saw. I weighed these with both tanks full on each. The XS even had some west coast dogs that probably add an ounce or two over stock. I didn't go as far as removing them to compare. Lol. Anyway, the weights.
    Later model XS 241.
    With the 18" Oregon speedcut bar and stihl 23RS narrow kerf chain.
    And power head only.
    Old 241 with 18" Forester and standard stihl rs .325 chain.
    Old 241, power head only.
    Both saws have aftermarket air filters. One oiled foam, the other dry. Both have the same outerwear pre filters. The foam unit would stick out about the same if I cut a hole in the hood. The old saw has original dogs.
    That scale weighs in pounds and 1/10 of a pound increments, not pounds / ounces.
    MAF143, Chud, Duane(Pa) and 3 others like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    The only differences I've seen between these saws are different coils and carburetors. Different part numbers on the flywheels but they look the same. That's it.
    MAF143 likes this.
