Stihl MS241 build
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Feb 12, 2024.
  1. Eggshooterist
    Eggshooterist
    Erff
    Lol. White cases, all former white plastics will be black. Orange hood.
    MAF143, T.Jeff Veal and brenndatomu like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    I think it will look better than that used motor oil stained mess it was.
    Ron T, Ohio, Duane(Pa) and 10 others like this.
  3. JimBear
    JimBear
    You should find/make an Echo emblem, that would really throw some folks
    ammoaddict, Duane(Pa), MAF143 and 4 others like this.
  4. Eggshooterist
    Eggshooterist
    Erff
    I know a guy. Lol. But, the cases are stihl white.
    Chvymn99, brenndatomu and T.Jeff Veal like this.
  5. buzz-saw
    buzz-saw
    Ct.
    Those look good , was that with RIT dye?
  6. Eggshooterist
    Eggshooterist
    Erff
    Thanks. Yes, Rit dye. I followed the instructions with adding vinegar and dish soap. Boiled in the 18 qt roaster over for 2.5-3 hours. I used the whole bottle of dye in 4 gallons of water plus the vinegar and soap.
    buzz-saw and MAF143 like this.
  7. buzz-saw
    buzz-saw
    Ct.
    It looks like it took the dye really well.
  8. Eggshooterist
    Eggshooterist
    Erff
    It did. Not shiney like doing a new saw but it hid the ugly. That was the goal. Now I need to get on DDM and order another filter or two.
  9. buzz-saw
    buzz-saw
    Ct.
    OK , so what are you going to call it.
    Do we need to start a "Name That Saw" thread?
    Eggshooterist likes this.
  10. Eggshooterist
    Eggshooterist
    Erff
    I'll take suggestions. Lol. No guarantees on what I pick. Money pit kinda fits it currently.
    eatonpcat, buzz-saw and Duane(Pa) like this.
  11. Eric Wanderweg
    That color scheme has me thinking Halloween. It must be Michael Myers :)
    eatonpcat and Eggshooterist like this.
  12. Duane(Pa)
    Duane(Pa)
    Centre Co.
  13. Eggshooterist
    Eggshooterist
    Erff
    My cylinder is back from Shawn Carr. It was a whopping $25 with return shipping. More to come once the Arctic GTFO of here again.
  14. JD Guy
    JD Guy
    Upstate SC
    Following…..My suggestion for a name is Stihl Stealth :)
  15. ammoaddict
    ammoaddict
    Granite Falls, NC
    I would name it Husqvarna wannabe.
    Deererainman and brenndatomu like this.
  16. Eggshooterist
    Eggshooterist
    Erff
    If you ran one you'd think otherwise.
    brenndatomu and JimBear like this.
  17. ammoaddict
    ammoaddict
    Granite Falls, NC
    Maybe so, I've only ran a couple stihls and I wasn't overly impressed. I like my Husqvarna and dolmar. I have heard very good things about the 241 but never had the opportunity to run one.
    brenndatomu likes this.
  18. Eggshooterist
    Eggshooterist
    Erff
    They all have made duds and standouts.
    brenndatomu, ammoaddict and JimBear like this.
  19. Eggshooterist
    Eggshooterist
    Erff
    I've decided, again, to port this saw myself. And I did just that today. I'm only showing the exhaust and intake as the extensive lower transfer work is someone else's genius that I emulated. The numbers ended up, how I read them, as 106° exhaust, 75° intake. I didn't touch the uppers. I widened the exhaust 65% of the bore diameter, which ended up being 3mm total. I think this is the prettiest exhaust I've managed to do.
    IMG_20240306_143728164~2.jpg IMG_20240306_141631329~2.jpg IMG_20240306_143740840~2.jpg
  20. Eggshooterist
    Eggshooterist
    Erff
    Muffler is matched to the port using the metal gasket as the guide. It was quite a bit larger than the port.
    IMG_20240302_095824413~2.jpg IMG_20240306_150839955~2.jpg IMG_20240306_151341157~2.jpg IMG_20240306_150850006~2.jpg
