Stihl MS241 build
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Feb 12, 2024.
  1. T.Jeff Veal
    Looks great, Steve
    Eggshooterist likes this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Franks mang.
    T.Jeff Veal and eatonpcat like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    Thanks. Hopefully you get to run it in May.
  4. Eggshooterist
    Eggshooterist
    Erff
    Something like that. Lol
    T.Jeff Veal, buzz-saw and eatonpcat like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    Got a bit more done. First I checked to see if my go to 1/5 scale rc car filter, that I put on saws, fits the 241. The answer is yes after removing the factory air filter twist lock mount. It clamps right on the stihl part on the carb. It doesn't interfere with the controls. Hood will have to be cut out obviously.
    IMG_20240213_134510828~2.jpg IMG_20240213_134452721~2.jpg IMG_20240213_134542269~2.jpg IMG_20240213_134534946~2.jpg
  6. Eggshooterist
    Eggshooterist
    Erff
    I have everything removed so I can pull the cylinder tomorrow. I timed it today and it was a real pain with the tiny plug and decomp hole for viewing through along with the reflections from the cylinder walls. Anyway, out of curiosity I asked Kevin what he gets with timing a stock 241 and we are a few degrees off from one another on exhaust and transfers but same on intake. Also, the uppers have staggered openings that I couldn't see with all the reflections. I use a flash light looking for the first crack of light in the exhaust port and do my best to see the uppers through the plug hole but the 10mm plug hole is tiny. He uses a different method that sounds like its more accurate. I don't plan on raising the exhaust or transfers anyway but I still like to be as accurate as I can. I might try again tomorrow with a magnifying glass to hopefully see in there better. Anyway, these are the numbers I got.
  7. buzz-saw
    buzz-saw
    Ct.
    Well done.
    Another DDM air filter saves the day.
  8. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. Those filters work well. I won't run one an off-road RC car, because they live in a cloud of debris, but on a saw, I see no fines. They aren't paper either. They are washable. I've out them on 3 saws so far. This one will be number 4. I'll have to order one here soon.
  9. MAF143
    MAF143
    North Central OH
    If I can't see in there real good I'll run the ring up in there with the piston to the top of the xfer I'm measuring, then put the piston back on the con-rod, put the cylinder back on and rotate up to just bump the ring. It's usually more accurate than peeking in a tiny hole at an odd angle...
    I'll shut up now since this is a family channel...
  10. Eggshooterist
    Eggshooterist
    Erff
    Lol. Yeah, I was a bit frustrated.
  11. Eggshooterist
    Eggshooterist
    Erff
    More 241 stuff...
    IMG_20240214_121332227~2.jpg IMG_20240214_121324729~2.jpg IMG_20240214_121353739~2.jpg IMG_20240214_121342615~2.jpg IMG_20240214_121214864~2.jpg IMG_20240214_121235645~2.jpg IMG_20240214_121221830~2.jpg IMG_20240214_121153124~2.jpg IMG_20240214_123424014~2.jpg
    Cylinder is perfect. Piston shows most of the machine marks.
  12. Eggshooterist
    Eggshooterist
    Erff
    IMG_20240214_144147063~2.jpg Numbers without base gasket. I used a magnifying glass to try and see the transfers better.
  13. buzz-saw
    buzz-saw
    Ct.
    Great pictures, the close up shots have great detail.
    Thanks.
  14. Eggshooterist
    Eggshooterist
    Erff
    Macro setting gets in close.
  15. Eggshooterist
    Eggshooterist
    Erff
    I took the cylinder to my trusted local welding / fab shop. They declined welding that mount to the cylinder out of concerns of warping. I'm going to run it. It's solid and if it ever gives me trouble, I'll send it Shawn Carr.
  16. JimBear
    JimBear
    He will get it done, he is magic man on stuff like that.
  17. Eggshooterist
    Eggshooterist
    Erff
    That's what I hear.
    T.Jeff Veal, brenndatomu and buzz-saw like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    I have an update. Firstly I'm glad I didn't sell this to anyone as it needs a flywheel. Its out of round, well, it doesn't center on the crankshaft correctly. It also wobbles. They must have over tightened it trying to compensate for the sheared key. $100 for a new one. It might take 2-3 weeks to get here. Also my OCD wouldn't let the AV mount go so it's on it way to Shawn Carr tomorrow. Lastly, because my nephew wouldn't take my porting slot, for the 543xp, I have reserved with Kevin, I'm being "forced" to have him port it. lol. Different build than my prescious. No machine work. Just gasket delete and whatever other magic he does. The beater 241 will be my go to dirty wood / GTG saw going forward. I should have it all back together before Denny's GTG. Currently the plastics are boiling in black dye.
  19. buzz-saw
    buzz-saw
    Ct.
    Stealth Bomber look.
  20. MAF143
    MAF143
    North Central OH
    What??? Not blue raspberry???
