Stihl MS192T cylinder differences
Discussion in 'Chainsaws and Power Equipment' started by stackowood, Mar 9, 2016.
  1. stackowood
    stackowood
    Oregon
    I have 4 or 5 MS192T/TC saws that I'm rebuilding and noticed that on the earlier T models up to 2007 the cylinder is different and the compression is higher.
    On the newer TC models with Ergo-start there is a groove in the cylinder wall extending just below the exhaust port. It reduces compression, and probably makes it easier to start, but why did Stihl do this? A 30cc saw is not tough to pull over. Everything else about the two cylinders looks the same, and they have different part numbers.
    The older T pushes about 175psi, and the newer TC only comes up with about 140 psi.
    clemsonfor likes this.
  2. NewToStihl
    NewToStihl
    Central Indiana
    That is referred to by Stihl as a "pre-exhaust groove", but I don't know the rationale behind it.
  3. clemsonfor
    Yea if a 30cc is hard to pull over you might have trouble lifting all but twigs that you cut
  4. Barcroftb
    Barcroftb
    The Mitten
    Does the older t cylinder fit on the newer tc saws?
  5. NewToStihl
    NewToStihl
    Central Indiana
    Yes.
    Barcroftb likes this.
  6. stackowood
    stackowood
    Oregon
    I just finished rebuilding a couple of TC saws with the older T cylinder (OEM) and they have a very noticeable difference in compression. With the carb limiters removed, and the muffler outlet opened up, they really run well.
  7. askfault
    askfault Guest
    This is confirmed as a fact?
    In error I have dimpled my 192tc cylinder wall attempting to repair a loose muffler and will need to replace it.
  8. NewToStihl
    NewToStihl
    Central Indiana
    See post #5.
    Scotty Overkill and Barcroftb like this.
  9. stackowood
    stackowood
    Oregon
    I have used a number of the 'T' cylinders #1137-020-1203 and they bolt in just fine. There is only one piston part number, so it works with either style cylinder if you are re-using an old piston. Dealer charges $99 for the P/C assembly... haven't found any aftermarket ones yet.
    Scotty Overkill likes this.
  10. Scotty Overkill
    I have two 019T's that will be getting overhauled this winter, will the crankshaft out of an old 017 work in the 019? I have a crank that is out of time......
  11. askfault
    askfault Guest
    Thank you for the sound counsel. Before checking for a reply here I called and Mark at Stihl confirmed that the 192tc is compatible with the 192t cylinder just as you folks have confirmed.
    Off to go get that done.
    :salute:
