Stihl 260 running HOT!??
Discussion in 'Chainsaws and Power Equipment' started by Dakota Hoarder, Mar 19, 2017.
  1. Screwloose
    Screwloose
    Yup, it will suck air just like you trying to drink the last of a milkshake.
  2. brenndatomu
    Maybe...but as stated above...your plug doesn't really show lean. A cracked line will make it run wonky though
    Ralphie Boy and Dakota Hoarder like this.
  3. NH_Wood
    NH_Wood
    Fuel line is pretty straightforward to replace - the grommet can be a bit of a pain to get through the tank opening - I use a bit of oil to lube the grommet before pushing through. Curved hemostats are handy for the install. If you are tempted to push the grommet through with a screwdriver - be careful - easy to make a mistake and puncture the new line. Cheers!
  4. brenndatomu
    I have curved extra long needle nose pliers that work pretty well...hemostats probably easier though, just because of being smaller/more compact
    Dakota Hoarder and NH_Wood like this.
  5. NH_Wood
    NH_Wood
    And the hemostats lock - this is a big plus. Cheers!
  6. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    That's why it's so cool here! So much gooder information.
    If you can't fix something by checking all the good advice you find here in the family, then it cant be fixed!
    Go team, go! :dex:
  7. Screwloose
    Screwloose
    So .......about those Powerball numbers............
  8. Ralphie Boy
    Ralphie Boy
    :rofl: :lol::rofl: :lol::thumbs:
    Had not thought of that. I'm in for $20!
    Screwloose likes this.
  9. Rumpy
    Rumpy
    Pioneer Valley, MA
    This reminds me of when my brother in law got a barely-used saw from his boss for free. Boss had said it ran hot, when it even stayed running. Brother in law found that boss had clogged the fuel line and the muffler deflector was blowing exhaust on the cylinder. He flipped the muffler deflector 180° and cleared the fuel line. No more problems.
    Now, I never saw the saw in question, and at the time I was too young to know anything about anything. So if this sounds like a load of bull, I'm just repeating what I heard. I'm just saying, where is the exhaust pointed?
  10. Screwloose
    Screwloose
    I'll admit to the deflector flip myself......... I can admit to a lot of things......... Some I might have to .........
  11. bushpilot
    bushpilot
    Eastern Washington
    That is most likely an exhaust leak. I'd pull the muffler off, check it and the gasket, and get a look at the piston while I was at it.
  12. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I pulled the muffler and checked it out nothing obviously wrong, checked the P and C both looked good. I'm going to attempt the fuel line and filter fix (it needs fixed anyway) and see if that solves the problem, getting parts tomorrow so we'll see how it goes.
  13. Fishnuts2
    Fishnuts2
    SE, MN
    I'm thinking that the muffler might be loose or it's gasket blown out. A hole in the muffler in the wrong place from a bad muffler mod would cause this too. I'd like to see some pics of the muffler when you get it apart.
    Thinking more about it, take the top cover off the saw and see if there are any obstructions to airflow from the flywheel. A 260 sends the exhaust out the right side of the muffler and the proper airflow helps accomplish this.
  14. L.Steiner
    L.Steiner
    oh
    Make sure the top of the muffler cover is under the lip in the top of the muffler body.
    Larry HOS
    Fishnuts2 likes this.
  15. Handsonautotech
    Handsonautotech
    Big Elk Meadows Lyons CO
    Waiting with baited breath to see the results of the fix.
  16. Ralphie Boy
    Ralphie Boy
    Still :popcorn: and :binoculars:
  17. Screwloose
    Screwloose
    Kinda scared for um. If he went to a dealer for parts he could have become infected with gottagettanewsawitis ......Scary stuff....... Sometimes has to be beaten outa ya by a frying pan.
  18. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Been there before! Last time when I went in (for my 461 recall) I resisted the impulse to buy a new saw. I got out of the store with a couple files and some B&C oil. Sometimes I think they do recalls just to get people in the store!
  19. Oldman47
    Oldman47
    Illinois
    I have to ask the obvious with my 026 experience. Does that have a summer/winter cooling air window on it and is it set right?
  20. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Yes one the back cover, just outside the air filter. The air window was covered. It was between 40-50 degrees when I was cutting. I wouldn't think having the cover on would make it that much hotter.
