Stihl 044 air leak?
Discussion in 'Chainsaws and Power Equipment' started by Andimus Prime, Sep 24, 2019.
  1. dall
    dall
    West Virginia
    if i remember correctly the sides of the gasket wont pass the piston so it may have been deleted but im not seeing any sealant either
  2. Andimus Prime
    Andimus Prime
    NW NC
    Had a few minutes to play with it this morning. Is this amount of rod to crank play ok? Piston had no play on the rod.
    F66EE0C0-349B-4807-B7B3-C9308405FAAF.jpeg D05326E5-7AE7-401D-8721-3B27803EC092.jpeg
    M2theB likes this.
  3. dall
    dall
    West Virginia
    side to side play is ok it is the vertical play that you dont want
    usually you can see a broken bearing cage if the big bearing is bad
  4. Andimus Prime
    Andimus Prime
    NW NC
    No vertical play at the crank or piston.
    SKEETER McCLUSKEY and dall like this.
  5. dall
    dall
    West Virginia
    your good to go then
  6. Andimus Prime
    Andimus Prime
    NW NC
    So I never got around to picking up a case splitter or flywheel puller. I ended up having my local dealer do the work. I figured he could do it better and quicker than I could. I got the old bearings off and the case halves cleaned up, put in new bearings and case gasket. I got the seals started but I’m not sure they’re seated deep enough. I think the clutch side is ok but I’m not sure about the flywheel side.
    4524E2C7-C8BC-488C-ABC0-CCC51CE68187.jpeg 0A01AE73-4298-4D61-9AD3-77AD364EC6B5.jpeg
    M2theB likes this.
  7. Nixon
    Nixon
    West Sunbury,Pa .
    Are those seals installed in the wrong direction ?
  8. dall
    dall
    West Virginia
    seals are put in backwards
  9. Andimus Prime
    Andimus Prime
    NW NC
  10. dall
    dall
    West Virginia
    once you do a few you will get better at them
  11. Andimus Prime
    Andimus Prime
    NW NC
    I don’t feel too bad about it considering this is my first rodeo. The way those seals beveled made me think they went that way.
    SKEETER McCLUSKEY, dall and M2theB like this.
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Yep, no worries. I’ve seen experienced mechanics drive the pto seal in wayyy too deep. Just get new seals and go slow. The pto side is easier on the 044 because of the crank clearance needed for the bushing; the seal lip won’t easily invert with that model.
  13. Andimus Prime
    Andimus Prime
    NW NC
    Well I actually tried to pull the seals, flip them and reinstall. I boogered up the clutch side but I thought the flywheel side went in nicely. If I should just do all new seals for peace of mind I will though.
    9F2C6641-4B42-4463-BF75-1CDF48C9628D.jpeg 4F33E172-6508-499C-B264-0EE5AE096E65.jpeg F4E021F1-C001-44ED-9770-608B1D59CA10.jpeg 0A1782B1-C2A2-425B-BFD2-B14DB6715239.jpeg 38D5BFFF-AAEE-4816-B3C1-333074415C04.jpeg
    Nixon and M2theB like this.
  14. M2theB
    M2theB
    Central Massachusetts
    Considering the price of seals versus the effort to get to them, I’d get new ones. Looks like you should get one new one anyway.
    Even if leak check passed, I’d always have that doubt in the back of my head.
    Nice thread by the way!
    Nixon likes this.
  15. Andimus Prime
    Andimus Prime
    NW NC
    Thanks to everyone for all the tips and advice! When BuckthornBonnie recommended new ones I thought about the cost of new ones vs the effort to replace them after everything was put together as well. I’ll get some new ones in.
  16. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Consider it practice so the new ones go in perfectly.
    Are you using a socket to drive them in? Make sure it’s the correct diameter and clears the crank and directly lines up on the metal of the seal. Avoid the rubber.
    Grease/oil on the inner lip and flywheel side crank, small amount of sealant on the OD. I prefer loctite 518 here since it’s anaerobic and won’t get into bearings or anything. Carefully set the bushing in after the pto is right. The little o-ring... not necessarily needed if you pack some grease in there and properly torque the clutch.
    Funny, I use the ring on 371/372, but I don’t use it for 044/440s. It’s easily available at Husky dealers, maybe that’s why? I also pack that bushing with grease.
    Andimus Prime and Nixon like this.
  17. Andimus Prime
    Andimus Prime
    NW NC
    I used sockets for both of them. 14 and 21 mm I think?
    BuckthornBonnie likes this.
