Stihl 044 air leak?
Discussion in 'Chainsaws and Power Equipment' started by Andimus Prime, Sep 24, 2019.
  1. dall
    dall
    West Virginia
    the 044 has a bushing on the clutch side that will crack if someone puts the clutch on too tight
    best thing to do is take the clutch side apart and inspect the bushing
    Chaz, huskihl, Nixon and 3 others like this.
  2. Nixon
    Nixon
    West Sunbury,Pa .
    No secret . I put the adhesive side towards the carb ,and muffler ,use an ice pick to locate the holes for the mount bolts .
    Chaz, M2theB and brenndatomu like this.
  3. cnice_37
    cnice_37
    Oh.... so you bolt on the muffler/ carb as well as the tape? That makes more sense then just applying the tape alone (which might be how I went about it... :whistle:)
    Chaz, huskihl, Nixon and 2 others like this.
  4. Andimus Prime
    Andimus Prime
    NW NC
    C66A2DE6-537E-48E9-A3D9-A29234F5F58C.jpeg Is this a seal? The circled area looks like there is a spring embedded in it. When I picked at it with a screwdriver, more of it came off which is what the arrow is pointing to. It felt like dry rotted rubber to me.
  5. brenndatomu
    Bingo. That seal is JUNK!
    Chaz and M2theB like this.
  6. Andimus Prime
    Andimus Prime
    NW NC
    Awesome. So I need a new crank and flywheel seal, a flywheel puller and case splitter, and gasket set. Anything else I should replace while I’m in there?
  7. brenndatomu
    You want to tear it all down? If not I'd just pop that seal out and push a new one in, done.
    Chaz, Nixon, M2theB and 1 other person like this.
  8. Andimus Prime
    Andimus Prime
    NW NC
    I ASSumed it all had to come apart to get to that seal. I’d much rather put a new seal on and get to cutting! :saw:
    Chaz, M2theB, huskihl and 1 other person like this.
  9. brenndatomu
    Get a new seal, drill a small hole in the metal part of the seal, run a sheet metal screw into the hole, clamp vise grips on the screw, pull seal out. Just be prepared to keep the bit from pulling through into the bearing right when the bit breaks through the seal wall...easy does it! A sharp nail could puncture it too...might actually dislodge the seal when you rap on the nail...if it does then you may not even need to "pull" the seal.
    This is the way the dood in the video posted earlier did it (drilled hole/pulled) and he mentions the hole at one point there...
    Chaz, M2theB, eatonpcat and 1 other person like this.
  10. brenndatomu
    I'm sure there are Youtubes on pulling seals this way too...I can look...
    Chaz, M2theB and eatonpcat like this.
  11. Andimus Prime
    Andimus Prime
    NW NC
    Don’t worry about it I’ll dig it up. Should I buy oem or aftermarket?
  12. brenndatomu
    Either...just don't get ultra cheap Chinese junk...a good seal is only a few bux...
    M2theB, Chaz, Andimus Prime and 2 others like this.
  13. huskihl
    huskihl
    There is a bushing on the crank that the seal rides on. You can remove it to make the seal easier to get out and back on. There may also be a thin o ring in the larger end of the bushing or still on the crank up against the bearing. I'd remove that too if its still in there and see if its still usable. If not, smear some sealant inside the bushing when you reinstall it after you insert the new seal. If you just tap the new seal in over the bushing, it'll most likely fold the lip out on the seal and the spring will fall out
  14. brenndatomu
    Yup, its the little details that will getcha...I've never messed with an 044...so good info! :handshake: :thumbs:
    If a seal has to go over a sharp lip on a shaft I like to use Scotch or packing tape around the shaft...slide the seal over the taped lip, remove the tape.
    Chaz, Andimus Prime, M2theB and 2 others like this.
  15. huskihl
    huskihl
    That works. I use a piece of my favorite smoothie can
    Chaz, Andimus Prime, M2theB and 4 others like this.
  16. M2theB
    M2theB
    Central Massachusetts
    I use the plastic window cut from a box of rigatoni. And I just found a spare on the mini’s
    huskihl, Chaz, eatonpcat and 2 others like this.
  17. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Check that bearing, too.
    Chaz, Andimus Prime and brenndatomu like this.
  18. Andimus Prime
    Andimus Prime
    NW NC
    Does anybody have a repair manual for this saw?
    Chaz likes this.
  19. Nixon
    Nixon
    West Sunbury,Pa .
    Check out this post on OPE . I know it has a listing for the MS 440 . So it’ll get you the info you need for the 044 .
    Stihl workshop manuals
    I think it’s in post # 4 .
  20. Andimus Prime
    Andimus Prime
    NW NC
    So I picked up a seal from my friendly neighborhood Stihl dealer, pulled my old seal with the sheet metal screw trick (worked like a charm!), and found this..
    Time for a new bearing too, right?
