Stihl 036 Pro
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Dec 3, 2013.
  1. rookie1
    rookie1
    Ya sometimes that stuff happens. I knocked a seal in crooked on the crankshaft cause I was so excited to hear it run. Put it together anyway, ran it then got a new one. Didnt mess the second one up.
  2. MasterMech
    Sometimes, even when you do everything right, it still don't work. Brand new seal in the timing cover on my big-block chevy. Installed on the bench, straight as an arrow. Balancer went on with no prob and yes, I oiled the seal lips before shoving the balancer on the shaft. Guess what is the only thing that f**%ing leaks on that truck. :mad: It leaks good too. I'm gonna have to tear it back apart this spring.
    DexterDay likes this.
  3. rookie1
    rookie1
    That stinks. I remember shop teacher putting seal in timing cover then making us install damper before tightening cover bolts so seal would be centered. He kicked a kid right in the butt for not doing that way. I did the way he said,I didnt want to get kicked! ;)
    Chvymn99 and DexterDay like this.
  4. MasterMech
    Hmmmmmm........ That's pretty much what I figured happened. I'm going in again anyways. I either have to figure out how to quiet down the timing gears or give up on them and swap it back to a double-roller chain drive. It's the timing drive that got me in there in the first place. The truck is an '89, which would have the Mark IV big-block in it and the notorious nylon fish-fin gears. My dad's '89 K3500 7.4L was that way. When we pulled the cover at 120K miles, many of the little gear teeth had snapped off. We had saved the engine just in time. So even tho my truck only has 80K on it, I had the front clip off for some body work, and figured I would nip that timing drive in the bud while it was easy to access. Opened her up and was surprised to find the later style drive, still nylon gear teeth but big, beefy ones instead of the little shark fins. Huh. Then I went to install the oil pan with a new gasket but the gasket was totally wrong.... "What the..... " Did some more lookin' and scratchin' noticed it had aluminum pistons in it, not iron, one-piece rear main seal and cast aluminum valve covers ..... "Hey, wait a second ...... " Turns out my truck is one of the ones that had the engine replaced under warranty from GM for overheating issues. I have a Gen V engine (long-block) with Mark IV accessories on it. Not a big deal now that I know but I had a few parts to return after that.... :rofl: :lol:
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    I like the Orange and grey better. I know it's silly, but I wanted the 550xp. The guy is actually a member here (silent). And Is an amazing person. Thank you to this person!
    MasterMech likes this.
  6. rookie1
    rookie1
    Im not too familiar with the gen v engines. Im more of a Ford man because of work. I have replaced old school nylon timing sets with the double roller bicycle style chain and sprockets. Had good luck with those. I kinda figured you were into gear drive timing sets by your avatar. Never messed with those. :)
    clemsonfor likes this.
  7. MasterMech
    Even more to the story, lol. I messed with a 5.0 HO in my '87 Mustang in my younger days. Did the gear set in that car and loved it. But it was much quieter under the cast aluminum timing cover of the 5.0 than the piece of tin GM calls a timing cover. I can hear the double idler assembly knocking against the cover at idle, lots of gear crunch in addition to the whine, which the mustang only had a subtle whine to it which I loved. Smooths out when engine speed picks up off idle but it still drives me up a wall. So if I can't get it to quiet down, I'm losing it for the double roller set. But sure does make a dandy avatar no?
  8. rookie1
    rookie1
    I never really thought about the difference in covers. Does the aftermarket make a cast aluminum cover for GM? I wonder if that would help.
  9. clemsonfor
    There is a lighty uses 550 here local on CL. Think they want $500 not sure what they cost new?
  10. DexterDay
    Northeast Oh
    550xp is about $579 new. You could likely get a brand new one one from Wicked Work Saws for $500.
    Used, I would be in for $350.
  11. clemsonfor
    OK it says $700 new. Wants $400 and has. 16&20" bar and severalchains. Must o made up slightly used part
  12. clemsonfor
    See a husky 394 in great shape for $625. Seems good to me if I was in market for a monster!
  13. mdavlee
    mdavlee
    There's been a 550xp in the local craigslist at home for $300 at a pawn shop.
  14. DexterDay
    Northeast Oh
    $300 ain't bad. In decent shape.
    mdavlee and clemsonfor like this.
  15. mdavlee
    mdavlee
    It looks a little dirty from the pictures. I haven't went to look at it since I don't like 50cc saws any way. I figure why buy it just to resell.
  16. MasterMech
    They do. And I have one. GM did a cast cover for the Gen VI engines ('96 - '00) if I remember right.
  17. rookie1
    rookie1
    Are you going to try it?
  18. MasterMech
    Yeah, but not if I can't find a good timing indicator for it....... Seems the ones for steel covers won't fit. I might have to make one.
  19. DexterDay
    Northeast Oh
    I'm not a fan of 50cc machines either. 60cc is where fun begins, 70cc and above that is where real saws live.
    I bought one because of all the rage of 50cc autotunes. . I hope it's worth it :)
  20. MasterMech
    I think you'll find that the newest generation of 50cc saws has quite the power advantage over the likes of your old 026/MS260. ;)
