Stihl 029 Super to 039
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Jan 27, 2020.
  1. T.Jeff Veal
    Yep, make sure you get a new roll...:thumbs:...:rofl: :lol:
    Horkn, Erik B and M2theB like this.
  2. M2theB
    M2theB
    Central Massachusetts
    I lost count how many times I pulled the coil to get the wiring chased back to where I thought it was right and the grommet fit and the white wall set right between the cylinder and carb house. I’m usually pretty good about taking pictures on the way out but missed this one.
    The next trick will be treading everything through the throttle/handle and over the AV mounts simultaneously.
    Two points on the Warhawk so far; the screw for the ground off of the 029 cylinder was too small for the Warhawk 039. But a short Husky M4 worked perfect, wish I took that pic.
    And the 039 kit doesn’t come with a plug or a decomposing valve. Luckily I had one already, brand new and I don’t remember why.
    Sandhillbilly, T.Jeff Veal and Horkn like this.
  3. T.Jeff Veal
    Making some good progress. Can't wait to hear it run
    Horkn and M2theB like this.
  4. M2theB
    M2theB
    I think this was a practice run, building the brake back before putting the rear handle/cover on first. I might be able to get done with the brake on but I think it’ll just be easier to pull the brake, get the AV mounts and cover together and build the brake again.
    No pics, I did check compression and it’s about 165
  5. M2theB
    M2theB
    I ended leaving the brake on and was able to make it work.
    Had to put a hole in the cover to account for the decomp valve. Once I did compression went from 120 to a little over 180.
    I’ll put a b/c on it tomorrow and see how that goes.
    PatrickNY, huskihl and T.Jeff Veal like this.
  6. T.Jeff Veal
    Sweet little sleeper saw now. Very nice.
    :tip::saw::thumbs:
    huskihl and M2theB like this.
  7. M2theB
    M2theB
    Looking forward to making some cuts tomorrow!
    Grabbed a couple more projects this morning cheap.
    MS361 in the back and a 046. Both came with a lot of parts and all the plastic and covers.
    T.Jeff Veal likes this.
  8. T.Jeff Veal
    I wouldn't know where to start. Glad you can do that.
  9. M2theB
    M2theB
    A bath!
  10. M2theB
    M2theB
    A little more mod to to muffler. Another hole and removing the exhaust guide at the ankle.
    PatrickNY and T.Jeff Veal like this.
  11. T.Jeff Veal
    Sounds gooder.
    M2theB likes this.
  12. dall
    dall
    West Virginia
    the closest one is not a 046
    it is a 066 the 046 has the carb mount made into it
    also the 046 doesnt have the av mount on the clutch side
    what size are the cylinder mount screws
    if 5mm its a 064 if 6mm its a 066
    also can tell by the oil pump and on the 066 the flywheel is wider than 064
    do you have the recoil ?
    M2theB likes this.
  13. M2theB
    M2theB
    Pretty sure it a 064 now that I’ve had time to mess with it.
    Seller wasn’t sure when I bought it but he had told me he thought it was a 046.
    52mm bore.
    B9324E96-8D11-4F3C-A26B-86FCCFB26BA3.jpeg 1A84E276-348A-46C6-8DE8-C9149EC85A20.jpeg
  14. dall
    dall
    West Virginia
    yes 064 thin cylinder base
    make sure if you do a complete rebuild you get the gasket set for the early 066/064 they are more expensive but the regular 066 /660 gasket wont work
    T.Jeff Veal and M2theB like this.
  15. M2theB
    M2theB
    Thanks!
    Stihl tearing it down for clean up. Just decided an hour ago to buy the flywheel puller. It’s not coming off easy.
    T.Jeff Veal and dall like this.
  16. T.Jeff Veal
    Nice, you going to keep it?
    M2theB likes this.
  17. M2theB
    M2theB
    I’m going to build it.
    See how it turns out. This is one I’d like to keep.
    I’ll build the 361 too.
    That’s how end up with these saws for the most part. Gettem in salvage condition and cheap and build them.
    Some I sell to finance the habit of building them back.
    Sandhillbilly, dall and T.Jeff Veal like this.
  18. T.Jeff Veal
    :handshake:
    M2theB likes this.
  19. M2theB
    M2theB
    Right tool for the job! 11 beans at HLS and a minute or less.
    Now for clean up and leak check on the 064AV
    Sandhillbilly, T.Jeff Veal and dall like this.
  20. T.Jeff Veal
