Stihl 028 Wood Boss AV - Early Christmas!
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Oct 24, 2020.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    The vent line is just to relieve any pressure build up in the fuel tank, while trying to prevent the actual fuel from coming out, correct?
    This looks like the echo vent. 2 for $6 shipped. I think that will work.
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Sorta, yah. Air needs to actually come into the tank with no fuel coming out. Some designs allow for air flow both ways.
    The air/carb box of 028s may be a little tight for the Echo style. I put one in one saw but routed a longer line and found a spot for it.
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    The line that was in there actually went out of the carb box and was in between the two plastic covers....Just venting to the outside air.
  4. LordOfTheFlies
    LordOfTheFlies
    NY
    Ah so when the carb sucks up the fuel there's replacement air instead of creating negative pressure, yes?
  5. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Yep. The problem is the size of the Echo vent fitting into that tight space. Some will fit, others require a different route similar to a ms250 vent (longer tube connecting to an Echo-style vent).
    Grub screws oem style will fit, but the Echo style has been better for me.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    Got some carb cleaner and starting fluid along with 2 quarts of Stihl motomix today.
    Used an old toothbrush and gently cleaned it out. Came out pretty good I think. This will be my spare.
    $10.99/qt for the starting fluid. Thieves.
  7. brenndatomu
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    I meant for the Stihl Motomix. Sorry. But the starting fluid was $3.75 so it's still a rip off.
  9. Yawner
    Yawner
    Louisiana
    I have never seen that jerry can, that is cool, I think I will buy one!
    Yep, 5 gal of mixed fuel is way too much for most of us, that is a lot of chainsawing!
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    Aw yeah I love the 5 gallon one. It's quite heavy but it's damm sturdy and I've had it for a while now (8 years) and couldn't be happier.
    Not only functionally cool but looks sexy too!
  11. Jnb
    Jnb
    New Brunswick
    Are you missing one of the hold downs on the air filter? I believe there is soposeto be 2 of them where they screw onto the carburetor studs.
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    There are 2 screws. But the other screw is on the orange plastic cover. You can just barely see it at the top of this pic.
  13. amateur cutter
    5 gal will run me about 4 days of cutting on the 064, 066, & 046. :(
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    Thanks for all the feedback on fuel consumption. I bought 2 of the Stihl Motomix quarts. That should do me good for a while. Of course, this all depends on if the thing will start once I get the new parts in there.
    amateur cutter and brenndatomu like this.
  15. amateur cutter
    I'm betting it will, it looks like you've got decent mechanical abilities for sure. If it was mine I'd wait on a new bar etc. till you get it running good. Those are solid old saws for sure. Enjoy.
    LordOfTheFlies and brenndatomu like this.
  16. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah I got pretty excited and ordered the bar and chain. I think the guy is sending one of them fancy new carbon steel carbide tipped chains.......receipt says "74 DL .325 chain"
    eatonpcat likes this.
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    Worketh hard, do thy research, have a little patience, and don't be shy to ask questions........and ye shall be rewarded accordingly.
    GOT THE 028 WOOD BOSS RUNNING BABY! WOOOOOOOOOOOOOO HOOOOOOOOOOOOOO!
    Now, a few things........
    The air filter I got has an extra nut on it - on my saw the nut is part of the cover and extends through the air filter to screw into the posts holding the carb. I decided to reuse the old filter.
    They screwed up my order and only sent me one fuel filter instead of two. I also received 2 oil caps instead of 1.
    I decided to leave the existing impulse line. I don't even know what an impulse line does but it looked like it was in good condition so now I have a spare impulse line.
    It took a few pulls to get 'er going the first time but when it snapped, popped, and crackled, there wasn't a soul within 1000 miles who was happier I tell you!
    It seems to idle a little low....so I'm going to watch some videos on how to tune the carb. Any suggestions are helpful. There are two screws - H and L on the right side above the handle.
    Here is the video of the saw running.
    VIDEO LINK
    Here are some pics. Can someone verify that this is how OEM Stihl parts are packaged? I believe it is since the oil caps read "STIHL" on them.....but who knows these days.
    2020-11-03 15.25.54.jpg 2020-11-03 15.32.43.jpg 2020-11-03 15.32.56.jpg 2020-11-03 15.33.01.jpg 2020-11-03 15.33.04.jpg 2020-11-03 15.33.09.jpg
    Cleaned out the carb chamber area with some carb cleaner and a flour sack rag. Made sure to cover the intake hole. New vent line on the left. Only had 1 of those screws.
    Here's where the vent line sits. The screw is on the left side of the hose.
    Here's the new air filter with that second nut I don't need on the right. You can see the old filter in the next pic does not have it.
    New spark plug installed.
    A little concerned that this isn't the right bar for the saw. Of course the pic is a bit shiny but if you look closely it says 024, 026, 029.........but no 028!!!
    New chain. Looks like it was cut from a reel.
    New chain on the left, NOS chain on the right. First difference I noticed were the holes in the drive links in the new vs the channel in the old.
    Also, the tooth on the old blade is a tad bit longer, maybe 1mm or .5mm.
    2020-11-03 16.12.25.jpg 2020-11-03 16.12.32.jpg 2020-11-03 16.12.36.jpg 2020-11-03 16.13.04.jpg
    brenndatomu and farmer steve like this.
  18. Chud
    Chud
    NC
    The grooves and holes in the drives are for moving oil. Just a change of design.
  19. farmer steve
    farmer steve
    top of the hill york co. PA.
    LordOfTheFlies . Good job. Saw sounds good in your vid. Idle seems good. From the looks of the sticker on the clutch cover I don't think that saw was used much. I think the new bar should work. Just compare it to the old bar to make sure all holes are the same.
  20. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Great job!! Now the countdown begins until your next one :dex:
