Stihl 026 fuel problem
Discussion in 'Chainsaws and Power Equipment' started by NBourque, Sep 6, 2018.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Around $5 if I remember right?
  2. drf255
    drf255
    Strong Island, NY
    2 different fuel lines exist. Do you have the straight version or the larger one shaped like an ā€œSā€?
  3. Fifelaker
    Fifelaker
    Fife Lake Mi.
    There are actually 3 different fuel lines, one is NLA. It is on the early 026's iirc. it has a smaller grommet, I have had to drill the hole in 2 tanks bigger to make the newer line fit.
  4. NBourque
    NBourque
    Maine
    I ended up putting in the straight version.
    Chaz likes this.
  5. NBourque
    NBourque
    Maine
    New fuel line and filter. Also rebuilt the carb. Went to start it for the first time with rebuilt carb n she started first pull on full choke. Ran for less than 10 seconds when I tried putting it on half choke it died. Would not start after that. Any ideas?
  6. dougand3
    dougand3
    North Alabama
    Probably carb rebuild didn't work. Did you pull welch plug and clean 3-4 tiny holes underneath? I'd just get an AM carb.
  7. NBourque
    NBourque
    Maine
    Forgive my ignorance. Welch plug?
  8. dougand3
    dougand3
    North Alabama
    metering side - lever/needle. An alum disk (~3/8" diam) that you pry out and clean out holes underneath. You gotta have a new one that fits to lightly tap back in.
  9. NBourque
    NBourque
    Maine
    Thanks for the info. I think at this point I may just order a brand new carb off eBay. Suggestions? Are any of the carbs that are listed for the 026/260 gonna work?
  10. dougand3
    dougand3
    North Alabama
    As huskihl posted, Definitive Dave has good ones. but he's out of stock. Look for WT-194 clone that is fully adjustable.
    huskihl, NBourque and Chaz like this.
