Steven's 3120XP
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Aug 26, 2014.
  1. mdavlee
    mdavlee
    He helped me out when I was learning to square file.
  2. Mastermind
    Mastermind
    Tennessee
    He's a fine old dude.
    He called me up after Jerry broke that first record last year.......he was on top of the world.
    Said he had orders for bike saws start stacking up before the chips all stopped flying. :)
  3. Chvymn99
    That's was freakin' amazzzzzing....:bug:....that was like slicing a hot knife through butter...awesome...
    concretegrazer and mdavlee like this.
  4. mdavlee
    mdavlee
    Did you see the lines on the wood that he hit every cut?
  5. Mastermind
    Mastermind
    Tennessee
    Here's a couple more pics.......I'm done for the day. I'm gonna hit the shower.
    The rough in is done on all the transfer passages. Tomorrow I'll do the intake ports, then slick it all up.
    I'll make a few posts about modding the carb.......but some trade secrets are involved there.
    cgraham1, basod, jchin and 8 others like this.
  6. Chvymn99
    :thumbs:.... Looking good....I swear I won't tell if you post them here.....:rofl: :lol:.... I suppose your going to tell us they are Dole Bananas...:rofl: :lol:....
  7. tlandrum
    tlandrum
    nope ,chiquita banannas
  8. HDRock
    what kind of chain and grind do they use?
  9. mdavlee
    mdavlee
    .325" usually. I would imagine it is full chisel but may still be semi chisel.
  10. cnice_37
    cnice_37
    Rookie question #236 : do the finger/ bridge ports direct towards exhaust side to promote earlier (or more complete) ignition due to spark plug electrode location in jug?
    Chvymn99 likes this.
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Mike got the last name respelled for ya, but its Jerry Gingras. Met him several times over the years at races and raced against.
  12. MasterMech
    I would think you would want them to exit towards the intake side to promote better/complete scavenging.
    Adirondackstihl likes this.
  13. Mastermind
    Mastermind
    Tennessee
    It's about more transfer flow.
    DexterDay, MasterMech and mdavlee like this.
  14. sam-tip
    sam-tip
    Waukee Iowa
    For a 3120 like this using 32:1 what is the breakin or recommend breakin. Then how hard can I push it or lean once broken in? I have been gental on mine so far. Does not take long to use a few gallons of fuel.
    DexterDay likes this.
  15. Mastermind
    Mastermind
    Tennessee
    Work em hard.......that's what they are made for Doug.
  16. basod
    basod
    Mount Cheaha AL
    When you remove material from the inside cylinder wall of the transfer - is this the case of two 12" pipes deliver more flow than one 24" pipe.
    I guess it's near impossible to grind the backside of the cylinder side transfer wall - without some type of rotating tip grinder(I have a cable driven grinder developing in my mind)
  17. mdavlee
    mdavlee
    For all out race saws boost ports are put directly across from exhaust to get old mix out.
    cnice_37 and MasterMech like this.
  18. Dynomite
    Dynomite
    Pennsylvania
    Cool. Looks a bit rough on the bar when he rolls the log with the saw and bar.
    mdavlee likes this.
  19. MasterMech
    So that is generally the function of a "boost" port? See I'm learning.....
    Are the fingers acting as boost ports here? To my inexperienced eye, it looks like they are simply adding more flow to the existing stream.
    Mastermind likes this.
  20. Mastermind
    Mastermind
    Tennessee
    There are several different ways to gain more transfer flow.......these type of ports are just simple and easy to do. They also have a high flow velocity......that matters on these engines.
    The ones across the transfer bridges are more for flow direction than they are for additional flow. They direct the incoming charge upward. The ones at the back over the intake act as boost ports and help clear the exhaust. In my mind I can see them working together to do both, without losing too much out the exhaust. You can't tell from the pics, but there are three different transfer heights involved here.
    Here's a pic of a few of the tools I use.
    Kg461, MasterMech, mdavlee and 5 others like this.
