Steps for reviving a billboard telling traffic this is a private road?
Discussion in 'The DIY Room' started by wildwest, Apr 14, 2016.
  1. savemoney
    Why not cut the letters out of wood, then nail them on the face of that sign. They may get old and faded, but the lettering will still be there with some remaining contrast to the background.
    Eric VW, Stinny, Horkn and 2 others like this.
  2. wildwest
    What a FANTASTIC idea Larry!!
    It would take me a long time as I can only run a jig saw for a few minutes at a time now. Is there such thing as 2" x 12" or wider like 2x16?
    Eric VW, Horkn and Woodwidow like this.
  3. savemoney
    you can make the wood as wide as you need it. use exterior wood glue and then clamp the boards together much as would be done to make a table top or carving board.
    Eric VW, wildwest and Horkn like this.
  4. Woodwidow
    Really good idea. the basic structure looks pretty sound. I was thinking that if you had a sheet of plywood the same size as the sign structure, you could do all the work at home and then screw or nail it the whole thing to the existing structure.
    Eric VW, Stinny, wildwest and 3 others like this.
  5. TurboDiesel
    Good idea
    and every couple years you can bring it home and take your time fixing it up, then put it back up
    Eric VW, Woodwidow and wildwest like this.
  6. Horkn
    Make sure it says
    YOU ARE LOST!! TURN AROUND!
  7. wildwest
    Not sure where, but Stinny suggested "DEAD END", that is brilliant too!
    Eric VW and Horkn like this.
  8. Stinny
    Good plan Larry. If the number of letters is minimal, jigsawing letters is very doable. If you decide to go this route wildwest & WildWildWest ...
    - Spend the extra $$ and buy a sheet of MDO marine grade 1/2" plywood, (finished both sides). It's worth every dime... won't de-laminate.
    - Once you have your letter patterns drawn on the MDO... if you have some, you can lay the sheet flat on top of some old pieces of 1-1/2" styrofoam insulation. The styro will hold the plywood perfectly as you cut out the letters (normal blade length zips through the styro below, without hitting the supporting bench/work table underneath).
    - Paint your letters.
    - Screw the letters onto the sign background using stainless screws so they won't rust. Even galv nails will bleed rust stains down surfaces. Use a cigarette butt filter as a paint "dabber" and touch up the screws.
    - In the future years, a new coat of paint on just the front surface is as easy as it gets. Tight nap roller... takes 5 minutes (letters are raised off the background surface). And, if a letter is damaged, you can easily unscrew it and replace or repair it. Save your letter pattern if possible.
    Eric VW, papadave, Woodwidow and 2 others like this.
  9. Greenstick
    Greenstick
    BIOWEAPON TEST AREA AHEAD!
    Eric VW, TurboDiesel, Horkn and 3 others like this.
  10. Stinny
    :rofl: :lol:... I like that one... a lot... :rofl: :lol:
    Eric VW, Horkn and wildwest like this.
  11. wildwest
  12. wildwest
    What could another name for this be? I am not having luck online with those words, is it like pressure treated?
    Eric VW and Stinny like this.
  13. wildwest
    Will this work? (it says choice of finishes including gloss below the pic that did not fit here.
    Stinny likes this.
  14. Stinny
    MDO plywood... [​IMG]... Medium density overlay panel, or MDO panel, is a paintable surface made of plywood with a weather-resistant resin overlay bonded to the wood by heat and pressure. The overlay, which has at least 27% resin content, resists water, weather, wear and degradation.
    Most lumber yards can get a 1/2"x4'x8' sheet for you but may not have it in stock unless there are sign companies locally who buy it from them. If you were going to free stand a sheet on a pole, you'd have to use an MDO sheet that was finished on both sides so it wouldn't warp eventually. But, because you're going to use it to cut out individual letters and screw them to a background, you should be fine with using a sheet that's finished on just one side. Having said that, if MDO isn't available, I'd get the best grade 1/2" plywood I could and prime and paint them really well, especially the edges.
    Eric VW, papadave, Greenstick and 3 others like this.
  15. wildwest
    Found it! Lumber store here has it, $70 for a 4x8 sheet, just not on the website.
  16. Stinny
    That's great. Are you going to free hand draw letters on the MDO and then cut them out? If you do, be sure to take advantage of any letters that are repeated... cut one out and then trace around it for the others. That might even help you decide what you want to say and whether you go with upper and lower case or all caps, making as many repeated letters as possible.
    Eric VW, papadave and wildwest like this.
  17. wildwest
    :emb: Haven't got that far yet, I am leaning towards stencils but.......I bet I could do ok free hand too;) Thanks for the tips!!
  18. savemoney
    you can make your own, or download what ever you want, then trace. Keep the font the same size and you should be good to go.
    Eric VW and wildwest like this.
  19. wildwest
    Thanks Larry! I am hoping to have help (guys from WWW's work) for the letter cuttings, a few extra hands will make a big difference! At this point I am gathering materials. I think I will try a free stencil site online and have them printed on heavy cardstock at kinkos.......
    Eric VW, Stinny and savemoney like this.
  20. ironpony
    ironpony
    Mid Ohio
    try this
    unclefess, Eric VW, wildwest and 2 others like this.
