Starting to think open face fireplaces ARE USELESS
Discussion in 'The Wood Pile' started by Nicholas62388, Nov 22, 2016.
  1. Horkn
    Air movement is the key with an insert, and also with a stove too.
    If an insert room is too warm, turn down the blower on the insert, and or get air movement going. For me. I turn on the central heating fan only and that gets basement air around the house.
    HDRock and bassJAM like this.
  2. bassJAM
    bassJAM
    Cincinnati, OH
    My parents insert doesn't have a blower. And they do constantly run the HVAC fan when it's running, and have small fans in all the doorways but even with their open floor plan it gets pretty hot in the house. But they seem to like that type of heat in the winter, they act like they're in their 80's even though they just turned 60.
    Horkn and HDRock like this.
  3. HDRock
    Maybe you should explain to them about moving cold air to the stove room and even it out the heat throughout the house
    papadave and Horkn like this.
  4. HDRock
    Oh, well I guess they already do that, I like 75 myself, 80s not that bad either and I'm 63:) I have always liked it warmer than some people 65 in the house is way too cold for me 72 and up
    papadave, BuckthornBonnie and Horkn like this.
  5. Horkn
    Take the locust and high btu stuff away from them then. ;).
    Nothing better than cherry and maybe they'll not cook everyone out?
    Hinerman, bassJAM and HDRock like this.
  6. Horkn
    72 is my limit for heat in the house. Higher than that and I'm in shorts, and that's it.
  7. ErikR
    ErikR
    Deep in the woods near Cable, WI
    I have an open fireplace too. It's your typical steel and fire brick box built in to the wall. Horrible for heating, but fun to watch and snuggle up by. I've been burnt up a lot of good wood in the past 5 years since we moved in here. A wood stove or an efficient sealed fireplace like the RSF Delta or Opel is on my list of improvements to make. I'd like a wood stove.. she insists that they're ugly and wants something built into the wall...
    The actual purchase of it keeps getting pushed back because of other wants. A couple of years ago it was a sub-compact utility tractor... This last summer I bought us a convertible because Nancy's days of riding on motorcycles are over.... I really hope to upgrade my wood burning situation this next year. Meanwhile, the oak and maple keeps accumulating and drying!
  8. Paul bunion
    Paul bunion
    Yes, open fireplaces are more than 100% inefficient. Besides not providing any heat they suck the rest out of your house.
    For a short while we had one of those open fireplace wraparound C-tube grates that tried to suck in air low and blow it out beyond the fireplace from the top. We as kids of course made newspaper 'cigars' that we smoldered in front of them to see where the smoke went and were amazed to see it U-turn at the top of the tubes and go back up the chimney.
    papadave, Oldman47 and Horkn like this.
  9. DexterDay
    DexterDay Administrator
    Northeast Oh
    You are doing it right my friend. Keep it up Brotha! You'll have Wood ready when you are!
    Horkn likes this.
  10. Star Gazer
    Star Gazer
    Right behind you
    Horkn likes this.
  11. Handsonautotech
    Handsonautotech
    Big Elk Meadows Lyons CO
    I use the fan on my HVAC system and it keeps the whole house about even. We have a soapstone stove which puts out a steady even heat so we do not get cooked out. I am able to get the room to 80 if I really work it, but most often it keeps it just right and holds the heat to morning.
  12. ROBESPIERRE
    ROBESPIERRE
    CALIFORNIA
    I have an open fireplace and it gets the room heated fine. No negative efficiency, that is just ridiculous to think.I would rather have the ambience than just heat.Best of both worlds. I use more wood yes, but I can just get more wood anywhere.People cannot give wood away quick enough around here.
    Backwoods Savage, Hinerman and Horkn like this.
  13. Horkn
    I thought the same until I got an efficient insert last year.
    I have to say that my wife was diametrically opposed to putting an insert in her beloved open fireplace. i had to find the biggest glass stove I could find. I stumbled across a bay window quadrafire 4100i on CL and scooped it up.
    Fast forward a year, and she loves the stove insert. She's even able to keep it pumping out heat while I'm away. It gives off great heat, has awesome light shows with the ghost flames, and wood actually last more than an hour. I burn the same amount of wood a year, but keep the entire house warm with that same 2.5-3 cords a year.
  14. Nicholas62388
    Nicholas62388
    Bucks County
    My girl has been against it also all becuz she likes the sight of the flame but once I showed her stoves with big glass windows she's all for it
  15. RobGuru
    RobGuru
    Carroll Valley, PA
    Just read through the whole thread... was very interested to see that other refer to an open fireplace fire as and "ambiance" fire. That's what we called fires on our open fireplace before we installed our insert. Insert went in when heating oil hit $4.00 / gallon. We've not purchased any oil in three years, and still have about 3/4 tank.'
    Our Enviro has a nice big window, and we can still get nice ambiance through the glass. Plus, part of the ambiance is FREE HEAT!
  16. DexterDay
    Northeast Oh
    But because you can't control the air going into the fireplace. You have a lot (a whole lot) of already warm air going up the chimney.
    All that air that is pulled out of your place has to be replaced with air coming in your house from outside. Every cubic foot out? Means every new cubic foot of air is cold coming in!
    All of my stoves have an Outside Air Kit (OAK) on them. So all the air they heat stays inside and all the air used for combustion comes from outside and goes outside.
    You'll be amazed at the difference in heat if you install an insert. We haven't used our fireplace in probably 5 years. We lose to much heat. There was a day (years ago) that I thought it was heating the house. It was only heating the room it was in and cooling the rest of the house (cold air coming in through windows, doors, and exterior wall outlets).
    Glad she likes the big window idea!! She'll really love the added heat!!
  17. bushpilot
    bushpilot
    Eastern Washington
    For cooking meat? :rofl: :lol:
  18. Horkn
    We call that a grill. Lol
  19. DexterDay
    Northeast Oh
    Dang autocorrect !!
  20. Backwoods Savage
    Keep in mind where ROBESPIERRE lives! If your climate is not too cold then a fireplace would not seem too bad. But if it is cold, as Dex pointed out, all that air has to be replaced from somewhere and that is with outside air...
    papadave, DexterDay, HDRock and 2 others like this.
