Stacking Wood
Discussion in 'The Wood Pile' started by Kimberly, Feb 2, 2016.
  1. Eric VW
    Sharp. Witty. The Mountain Man of New Hampshire has spoken.
    :thumbs::D
    1964 262 6, Horkn and NH mountain man like this.
  2. NH mountain man
    NH mountain man
    WMNF N.H.
    Thanks for listening!:thumbs:
    1964 262 6, Horkn and Eric VW like this.
  3. Eric VW
    :handshake:
  4. BDF
    BDF
    Excellent- thanks for posting that, I obviously had it wrong.
    English is merely my first language (still considering which one should be second), I just hope it is not my best language....
    Brian
    Horkn and 1964 262 6 like this.
  5. BDF
    BDF
    Or drive two nails fairly deep into the split and touch the MM probes to the nail heads- faster and easier than splitting a split to measure moisture IME.
    Brian
  6. oldspark
    oldspark
    NW Iowa
    Even that has it's variables depending on the hertz. Skin effect.
  7. Kimberly
    Kimberly
    The Kangaroo State
    That dependents on the frequency of the current; the higher the frequency, the closer to the surface of the wire the current flows; AC of course.
    1964 262 6 and Eric VW like this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    Yes it does, if I try to cut too much wood or carry too much it does hertz.
  9. Eric VW
    You're on a roll here lately.....:D
    Horkn, NH mountain man and 1964 262 6 like this.
  10. oldspark
    oldspark
    NW Iowa
    Not sure how we got to this point in a thread about stacking firewood. LOL
  11. MN woodcutter
    MN woodcutter
    MN
    I only stack this way when the wood shed it full. It's too time consuming. Stacking in the wood shed is quick and easy and I never have to worry about stacks falling over. 20151122_153404.jpg Screenshot_2016-02-04-20-46-59.png
  12. Kimberly
    Kimberly
    The Kangaroo State
    Nice, is that tyre for holding wood as you split it with an axe? I saw a video where someone used an old tyre to hold the wood as he split it.
  13. Eric VW
    Yep.
    :rofl: :lol: Tire, here in the U.S....:thumbs::D
  14. Backwoods Savage
    Only problem with this theory that the mm don't lie is that if you put 3 or 4 meters on the same log, you'll usually get 3 or 4 different readings. Perhaps the more expensive ones may be better but I've seen a professional model and again, I questioned it. Mainly because we tested it more than once in the same log and got different readings. I will say that the wood we tested was very dry. I don't know what one would get if the wood was up around 20-25%.
    NH mountain man and Eric VW like this.
  15. Backwoods Savage
    No. Just build the ends good and all is well.
  16. Horkn
    Simple solution, use the scientific approach. Average the readings.
    Star Gazer and Eric VW like this.
  17. CuckooChris
    CuckooChris
    Eastern PA
    It's my fault... and it appears I need to research a few more 'levels' of how current travels:emb:.
  18. Dan
    Dan
    SW Missouri
    I like to mess around with stacking wood. It's good therapy. :faint:
  19. Fanatical1
    Fanatical1
    That is one beautiful stack of firewood Dan! Looks like fresh cut red oak maybe?
    That's a nice view you have too.... :)
  20. bushpilot
    bushpilot
    Eastern Washington
    Well, we all agree it is not rocket science. If one reading is 20% and another is 25%, then it is too wet. If one is 15%, and another is 18%, it is OK. The meter remains a useful tool, despite the insignificant inaccuracies.
    Remember, we are cutting the stuff with chainsaws, and maybe measuring with a stick, and throwing it in stacks in the yard to dry. Good enough is frankly good enough.
    Greg
    HDRock, milleo, Star Gazer and 3 others like this.
