Squished my 346 what do i need to do?
Discussion in 'Chainsaws and Power Equipment' started by concretegrazer, May 14, 2014.
  1. Stinny
    Let her rip… :tree:
    MasterMech likes this.
  2. MasterMech
    Either way. I would be inclined to leak check and then run it.
    mdavlee and Hedgerow like this.
  3. cwn877
    cwn877
    Central Pa
    I'd run it and see if there are strange noises or heat build up
    mdavlee likes this.
  4. NH_Wood
    NH_Wood
    I'd pass on running it until you give it a good once over - air filter shifted and carb may be loose - enough to draw some air - might be too tempting to let it run for a bit and burn her up. If it were my saw, I'd be breaking her down and checking for all damage I could find - put her back together if all seems well and then test her out. Cheers!
    concretegrazer likes this.
  5. mdavlee
    mdavlee
    Where's flimsy husky boy at to see that?
    Hedgerow likes this.
  6. Hinerman
    Hinerman
    NE Oklahoma
    Well, if it was a Stihl, he would still be cutting wood with it and we wouldn't be having this discussion ;)
  7. concretegrazer
    concretegrazer
    Southwest MO
    Bring yours over and we'll see.:cool: I'm not going to try it on mine.:loco: :crazy:
    Hinerman, Stinny, DexterDay and 2 others like this.
  8. Jon1270
    Jon1270
    Pittsburgh, PA
    I'd just try starting it. Being mashed into the mud isn't going to cut an impulse line or screw up an intake manifold -- at least, not without tearing off the top cover first. It's not going to ruin the crank seals, either. If such an accident were to cause an air leak, I expect it would be a crankcase fracture. That doesn't seem likely given the condition of the surrounding plastic, but if the case is somehow cracked then the saw is scrap no matter what you do. I suppose that discovering a leak via vac/pressure test rather than by running it might preserve the value of the top end, but I'm not sure I could be quite that cautious in your position.
  9. MasterMech
    I asked him if the clutch ran true to make sure the crank wasn't bent for a reason. At that point, with the photos and the fact that the major mechanicals seem to be ok, the saw should be safe to try and start.
    If it acts funny then shut it down but running it for 20-30 seconds with no load, even with an air leak isn't going to fry the top end.
  10. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Options as I see them.
    Put it on craigslist as slightly used only cut a few cords !:)
    Send a picture of it and a picture of the tractor to Husky and maybe they will send you a new saw for the use of it in their advertising!:)
    Post it here as free and then lock your door before the "Hoard" beats it down!:)
    Hope for the best!
    Gary
    concretegrazer and Jon1270 like this.
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    That 346 dont look to bad at all for what you said it went through. Tear down, look over, fix it back up. Easy as pie.
    concretegrazer, Hedgerow and mdavlee like this.
  12. concretegrazer
    concretegrazer
    Southwest MO
    Ran it for a minute.... she sounds good! Minus the gas spraying everywhere. Lucky lucky lucky.
    Anyone know where I can find a silver clutch cover? All I've seen are the orange. Any thing I should change while its torn down?
  13. Hedgerow
    Hedgerow
    SW Missouri
    TK from sawhawgz can hook you up...
    mdavlee likes this.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    I'd put a orange cover on it.
    mdavlee likes this.
  15. Cut4fun
    Cut4fun
    OHIO Redneck
    Some of the NE 50cc 346's came with orange covers from factory like this one. XPG
    Hinerman, concretegrazer and mdavlee like this.
  16. nate
    nate Banned
    Palmer, AK
    Are there pics of the damage?
  17. cwn877
    cwn877
    Central Pa
    At the beginning of this thread Nate but you have to look close:emb:
