Square ground chain question
Discussion in 'Chainsaws and Power Equipment' started by JD Guy, Nov 25, 2026 at 8:55 AM.
  1. JD Guy
    JD Guy
    Upstate SC
    I’m looking to try some square ground chain on my Stihl MS 400C. I use it predominantly for felling (not often currently as still working up downed trees from Helene) and bucking. The trunks are clean little to any dirt so I’m of the opinion that I could get some benefit from this chain. Use Stihl RS for most all saws now. Is the Stihl Hexa a good choice, or are there others that you would prefer?
    Edit: 25” Stihl light bar
    Thanks! Happy Thanksgiving to all:stirpot:
  2. Eric Wanderweg
    If you're asking about square ground then I'm sure you've heard about the benefits of it over regular "round" chain.
    Hexa and square are 2 different animals altogether.
    The downside to both square and Stihl Hexa chain will be the re-sharpening. Hand filing square chain is a tedious process with a steep learning curve, especially at first. It takes a while to develop the hand-eye coordination and muscle memory.
    Although I've never run Hexa, as I understand it, all you'll need to re-sharpen it is Stihl's proprietary files to maintain the factory geometry. Hexa over square to me sounds like the path of lesser resistance, if you're itching to try something slightly better than regular round chain.
    If you're really gung-ho about square, there are several manufacturers that sell factory square ground chain. I can only speak for the Oregon flavor, which IME performs decent out of the box but not as aggressive as the square ground that I sharpen myself. The factory angles are optimized for durability over speed and the rakers are set at a very tame height.
  3. JD Guy
    JD Guy
    Upstate SC
    Eric, Thanks for weighing in! So, hand filing square ground chain would be a steeper learning curve than round chisel? I’m not a master at hand filing round but good enough to keep chains sharp and cutting:thumbs:. I cheat and use the grinder if I find metal or hit a rock though.
  4. Eric Wanderweg
    Hand filing square chain is absolutely maddening at first :whistle: But if you're determined enough to learn, the section Square filing chains is full of awesome information by a lot of highly respected people, and there are plenty of YouTube videos of various utility online that can help you master the craft. Round file, full chisel chain sharpening is still the easiest game to play if you're putting a fresh edge on your chains yourself and not paying Joe Schmo to do it for you.
  5. JimBear
    JimBear
  6. The Wood Wolverine
    Bunch of years ago I was given a few lessons on square filing. It really isn’t that difficult but seeing it done did help. Here’s the best vid I’ve found to help understand and learn it.
    The most difficult issue is converting round chains to square. It’s hard on the files, which are expensive. After they are filed (or ground), it’s a good bit easier to maintain that profile.
    if you simply want to try a loop, I’d be willing to grind one for you. Feel free to send me a PM. One thing I feel strongly about is setting the depth gauges with a progressive plate so I’d wanna do that as well.
    After running square, bucking/felling and milling.. I found it is more durable than round, in clean wood. There’s more material at the working edge. It cuts smoother than round by a good bit and it’s faster (in every experiment/test I’ve ever done).
    Duane(Pa) and T.Jeff Veal like this.
