Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    I'm 99% sure I know what chain that is. I think that is the only cutter I touched up so far on that chain. It is a Stihl RSL that I had filed one time. I looked real quick and did not see the one I had filed. I'll look again tomorrow.
    Woodsnwoods and ChipsFlyin like this.
  2. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    When it comes to chisel filing. Repetition is your friend !!!
    You almost Need to commit to chisel filing , to get good at chisel filing .
    ALOT of the work is muscle memory and it takes some time to establish those.
    My big break learning to chisel file came in 83 when my boss said . Here's a file , have Larry show you how to file chisel bit. I was 23 and chasing under an American Track Loader. On Revilla Is. Actually 2nd loading. Bumping knots. Running a 2100 Husky 36" bar full skip 404. I had to file it a few times a day. When Larry told me what to do, there wasn't any arguing. Great guy.
  3. Cold Trigger Finger
    Cold Trigger Finger
    I found some new loops of 72LG I had stashed yesterday while looking for something unrelated. Maybe I'll order a couple files.
  4. Andrew999
    Andrew999
    Iowa Des Moines
    yes, I used it too))
    Woodsnwoods likes this.
  5. Moparmyway
    Moparmyway
    New York
  6. Cold Trigger Finger
    Cold Trigger Finger
    Beautiful !#!
    That looks like my bushlin grind !
    That will gobble thru conifers !
  7. Moparmyway
    Moparmyway
    New York
  8. The Wood Wolverine
    Woodsnwoods and Moparmyway like this.
  9. Cold Trigger Finger
    Cold Trigger Finger
    Looks like. Can see the dresser marks on the underside of the top of the cutter.
    Mopar; if you get a chance , pick up a set of cluster dressers.
    Looks good tho !
  10. Moparmyway
    Moparmyway
    New York
    Yessir, twas ground.
    I've not been able to find the cluster diamond dresser in a threaded version.
    The way they are setup, the diamond is on the end of a threaded adjuster.
  11. concretegrazer
    concretegrazer
    Southwest MO
    Madsen's has them.
    Moparmyway and Rope like this.
  12. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Archer 3/8 lopro. Sorry, the pics are not super clear at the corner.
  13. Grahamt
    Grahamt
    Leeds
    Sounds like you put a lot of pressure on the file
    mdavlee likes this.
  14. mdavlee
    mdavlee
    I do. I'm hard on files when converting chains over
  15. Grahamt
    Grahamt
    Leeds
    Ahh so your changing it from curved to square? Sorry I’m a newbie on chain sharpening, my saw now cuts better going up than down , Plus going down I get a curved cut
  16. mdavlee
    mdavlee
    Yes
    The Wood Wolverine and Grahamt like this.
  17. huskihl
    huskihl
    Flip your bar around and try it. You may have uneven bar rail wear
  18. The Wood Wolverine
  19. DexterDay
    DexterDay Administrator
    Northeast Oh
  20. SquareFile
    SquareFile
    somewhere
    GTG guys racing with those Saber roller nose bars, use the correct gauged chain ffs. :hair: lol
