Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. mdavlee
    mdavlee
    There's longer than the normal 7". Used to be double ended which were awesome.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    So there is no difference in thickness and width?
  3. mdavlee
    mdavlee
    Not that I've noticed in 5 brands of double bevel. I didn't ever measure with calipers to see either.
    Rope, Moparmyway and 94BULLITT like this.
  4. The Wood Wolverine
    In the 3 brands I’ve used, no. Hold them end to end and they’re the same. Bahco Stihl and SaveEdge.
  5. 94BULLITT
    94BULLITT
    Thanks.
  6. J. Dirt
    J. Dirt
    Picked up an Oregon 72cl square yesterday and a couple files going to give them a try. More of a reference chain for me than anything I guess. 063F121C-832B-4D40-9390-7DD28C072FDB.jpeg 7DB95897-C849-4F5F-8C52-29FDF4E5BF3F.jpeg 2231707D-2434-47D5-A863-0E1C793ED39D.jpeg
  7. concretegrazer
    concretegrazer
    Southwest MO
  8. Moparmyway
    Moparmyway
    New York
    Wizzard, I tell you ...... Wizzard !!!!
    Got pics of that tooth oriented in your vice as you are filing it ?
    concretegrazer, mdavlee and J. Dirt like this.
  9. concretegrazer
    concretegrazer
    Southwest MO
    I'm far from a wizard but thanks. I try to keep the vice level. Im getting more strap on the left for some reason.
    Rope and Moparmyway like this.
  10. Moparmyway
    Moparmyway
    New York
    Its a mutha to get that file in there .............. I'm still in awe of you getting that 0.325" tooth looking like that with that file
    Rope likes this.
  11. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Yes
    Rope likes this.
  12. Rope
    Rope
    Alaska
    Just got a few Viiala DB from Madsens, they are nice, must have some extra chrome compared to a few other brands. The seem to be more silver. My homelite410 vise should be at the PO today. I will try them out. I have some save edge that I have been using. From a visual QC the Viiala seem to be better. To my eye the SE seem to have chattered as it went through the process. The edge lines are straight and crisp.
  13. Rope
    Rope
    Alaska
    New to square filing. Yesterday I cut with a fresh loop of 72cl. While it felt factory sharp, I just finished practicing filing. I am very light handed to follow and learn the angles. I spent an hour on a 72 drive loop, and used a led light and magnifying glass to check each tooth and try and keep factory specs. I also used a Viiala and found it much smoother than the Save Edge. Maybe I am being more aware/gentle I did not feel the chatter that I did with the SE. I filed on the bar, anxiously waiting on my MM vise. If I was forced to chose a file the Viiala would get the nod. I was looking at the SE with a magnifying glass, the edges look wavy. I will get some pick up later.
  14. Rope
    Rope
    Alaska
    Here is the 72cl I touched up, have some consistency to work on. It cut really good in the load of white spruce I got this morning. They were done with the Viiala db 8B1863B6-B99A-41F4-AB56-243F173F7878.jpeg EEA5ED01-F050-41EE-8B09-5DF6E2CA735A.jpeg 519B079E-B995-413C-A894-088D817874EA.jpeg 453CEC17-3FB6-4546-8981-F67BB00A8110.jpeg 74914C5A-A022-4E76-AC72-9F61A309B921.jpeg BE7576B7-8B99-4EF3-87EC-C419B6F1FD95.jpeg 51EEF5D3-70A1-4C04-B44F-074ECED3E74E.jpeg
  15. Moparmyway
    Moparmyway
    New York
  16. Rope
    Rope
    Alaska
    mdavlee and huskihl like this.
  17. Moparmyway
    Moparmyway
    New York
    If it cuts good, then it cuts good.
    The side beak'd cutter in my avatar cuts fast for a few cuts, but isnt terribly durable
    Two more light strokes to the left picture above made it as sharp looking as the right hand picture
    You are closer than you think !
  18. Rope
    Rope
    Alaska
    It cut really well, nice long chips, cut 3 spruce, limbed and cut 50 or so rounds. On the last round the chips was 3/4 to 1 1/2 were long ones and 1/4 or so the short ones. Right at 20” tree, standing dead beetle kill, temp was -6*. To be honest it was dark when I started and did not pay attention to the chips. The last of the rounds I just happened to look, picked up a handful and looked at them.
  19. Rope
    Rope
    Alaska
    Got my MM vise in yesterday, from what I hear this will help me out with my journey.
    mdavlee and Moparmyway like this.
  20. Rope
    Rope
    Alaska
    Thanks for the encouragement.
