Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. Moparmyway
    Moparmyway
    New York
    Single bevel file this time
  2. Redfin
    Redfin
    central Pa
    I may have to give one of those a try Kev.
    Moparmyway likes this.
  3. Redfin
    Redfin
    central Pa
    Looks good.
    concretegrazer and Moparmyway like this.
  4. Moparmyway
    Moparmyway
    New York
    I've got a box getting ready for you ............ I'll see if I have a new one to throw in for you to give a run with.
    I'm not a fan of them .......... I preferr the double bevel first, then the triangular 6 sided, then these single bevels
    Thank you my friend !!
    concretegrazer likes this.
  5. concretegrazer
    concretegrazer
    Southwest MO
    What don't you care for with them besides the value stinks?
    I haven't forgotten about the chains. Ones done just need to finish up the other.
    Rope and Moparmyway like this.
  6. 94BULLITT
    94BULLITT
    Frederick County, VA
    What does a single bevel look like?
  7. concretegrazer
    concretegrazer
    Southwest MO
    Hedgerow and 94BULLITT like this.
  8. 94BULLITT
    94BULLITT
    Thanks!
  9. Moparmyway
    Moparmyway
    New York
    They flex the most out of any file, I’m a little heavy handed
    Single bevel 54DF244C-8B65-430A-BD38-50721E43E36A.jpeg A7D8E5D1-B95C-4567-BBC2-7D794F983110.jpeg
    Double bevel
    ACDFE7C1-860D-41AF-8D8E-CA3560CC2DD5.jpeg CCB4865E-CBC6-4EC9-A80C-BC08F2E78FA6.jpeg
  10. J. Dirt
    J. Dirt
    Guess I’ve got to go back and read this all from the beginning :eek: but I just inherited some chains that might be a good trial for me to lay the file too. I’ll have to try it and give some pictures.
  11. mike bayerl
    mike bayerl
  12. Moparmyway
    Moparmyway
    New York
    Thank you Sir !
  13. Moparmyway
    Moparmyway
    New York
    Here is why the triangular 6 sided file digs in ............ probably wont grab the strap as much as when its on a curve, but it digs into the driver then, and this is with .404, these pictures are all of the same tooth
    2017-10-31 18.00.37.jpg 2017-10-31 18.00.56.jpg 2017-10-31 18.01.12.jpg 2017-10-31 18.02.22.jpg 2017-10-31 18.02.11.jpg
    Why I preferr the double bevel over everything else. Can even get away with .325 and a double bevel ............. although the single bevel really shines with .325, because it has the lowest cross sectional thickness and doesnt dig into the straps or drivers (depending on cutter alignment setup) as much as the others. NOBODY, and I mean nobody will be able to file .325 square with a triangular 6 sided and be better than a sharp round .325 full chisel
    Rope and ChipsFlyin like this.
  14. SquareFile
    SquareFile
    somewhere
    I don't have experience with either, but I accept your challenge if you send me chains and a file. I'll send it all back and shipping.
    Rope, ChipsFlyin and Moparmyway like this.
  15. concretegrazer
    concretegrazer
    Southwest MO
    Don't waste your time. If I can do it I'm sure you can.
  16. Moparmyway
    Moparmyway
    New York
    I'll send each one of you a loop of .325 along with a FAT triangular 6 sided square file (like pictured).
    I'd love to know how you wizzards can fit that beefy mutha in there and have a chain thats faster than sharp round. I'm not talking silvey or ground, not single or double bevel either ............. I'm talking fat 6 sided
    This is 404 pictured
    concretegrazer and Rope like this.
  17. concretegrazer
    concretegrazer
    Southwest MO
    The riddle is easy to solve. Just get a stihl 3 corner & see if it's smaller. Or send me one of yours & I'll send one with these chains.
    Rope, mdavlee and Moparmyway like this.
  18. Moparmyway
    Moparmyway
    New York
    I'll send you one !!
    I've got a bunch of single and double bevel files that will work Sir, I was pointing out that the fatso triangular 6 sided has its place with 404, not 325.
    You two chain wizzards are schoolin me on using that thick momma triangular 6 sided with 325 so its faster than round, yes ?
    Rope, mdavlee and concretegrazer like this.
  19. 94BULLITT
    94BULLITT
    Are there different size double bevel files?
  20. The Wood Wolverine
    Not that I'm aware of.
    94BULLITT likes this.
