  1. The Annual Tradition is Back!!!! It's time for our 13th Annual Firewood Hoarders Club Secret Santa Gift Exchange! Deadline is coming fast, sign Up will be closed on Saturday, November 22nd at Midnight (central time). Get into the Christmas Spirit and join up in the Secret Santa fun by clicking on the link below! Official FHC 2025 Secret Santa Gift Exchange
Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. Moparmyway
    Moparmyway
    New York
    I would have already done it, except that its electric
    Skippy, 94BULLITT and Hedgerow like this.
  2. trx250r180
    trx250r180
    when i looked close at those cutters ,i think they cut made my eyes bleed ......
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    Rewind the motor:cool:
    Skippy, DexterDay and Moparmyway like this.
  4. Moparmyway
    Moparmyway
    New York
    Now this PS3 is ready for use !!
    Skippy, DexterDay, mdavlee and 3 others like this.
  5. Cut4fun
    Cut4fun
    OHIO Redneck
    My memory isnt what it used to be so if I already posted this overlook me like usual. 1 of these takes the square bevel file. The other can be made to work very easily too.
    Skippy, Hedgerow and mdavlee like this.
  6. 94BULLITT
    94BULLITT
    I have a Granberg G106b and I can get a double beveled file to go in it. I just can't get the right angles. I'm sure it could be modified. I also have an Oregon file jig and the file will fit in it but it is a sloppy fit.
  7. Freakingstang
    Freakingstang
    The Grandberg 107 has a bushing. you can see it on the white towel in the second pic. It holds a normal chiset bit, and you spin it 360 degrees to get the angle you need. I tried a couple of the old oregons, stihl, and mac file holders and could psychically fit a chisel bit, but couldn't get the right angles. found this one at a local shop new in the box in his upstairs obsolete junk parts....
  8. 94BULLITT
    94BULLITT
  9. Freakingstang
    Freakingstang
    this is old skool, like 20 years at the minimum. I've had it for 7-8...They haven't made any in years... you have to be on the lookout...get in good with your local old dealers...
    Skippy and mdavlee like this.
  10. Cut4fun
    Cut4fun
    OHIO Redneck
    The master of machine work and ingenuity made this stihl one to do any angle you can ask from it. work or race. :drunk: stihlsquareguide.jpg
    Skippy, Hedgerow, mdavlee and 2 others like this.
  11. mdavlee
    mdavlee
    Adam?
    Skippy and Cut4fun like this.
  12. trx250r180
    trx250r180
    look at the difference in width of the ripping chain on the left (carlton) and stihl rsc on the right ,if a guy was making one of them racing chains would the thinner chassis be a good thing ? These are sawmill chains is why the 10 degree top plate ,ground on the usg ripping chain 012.JPG ripping chain 011.JPG
  13. Moparmyway
    Moparmyway
    New York
    Thinner cut = faster cut
    Skippy and trx250r180 like this.
  14. Moparmyway
    Moparmyway
    New York
    One is semi :bug:
  15. trx250r180
    trx250r180
    Ripping chain comes semi,the round corner gives a little smoother cut for finish
    Skippy and Moparmyway like this.
  16. Cut4fun
    Cut4fun
    OHIO Redneck
    Yes there is thinned race chain. I used to own some of them. You have to have the whole chain apart and have inside the cutters milled. Then put back together.
    IMO it still comes down to the filer of the chain. If you had 2 exact cutter chains the thinned one might be tenth or so faster per cut. But you have a lot of extra work in it or lot of extra cost.
    Which if the cutter is still filed crapper it will just be a thinned crapper. ;)
  17. Moparmyway
    Moparmyway
    New York
    In other words, the angles and edges of the knives make it or break it
  18. Hedgerow
    Hedgerow
    SW Missouri
    I will sacrifice some width, if it can have a taller tooth...
  19. WKEND LUMBERJAK
    WKEND LUMBERJAK
    You ever get to run that 404 you filed up.
  20. WKEND LUMBERJAK
    WKEND LUMBERJAK
    Let me look when I get home I may have a 30 or 32 inch bar.
