  1. The Annual Tradition is Back!!!! It's time for our 13th Annual Firewood Hoarders Club Secret Santa Gift Exchange! Deadline is coming fast, sign-ups will be closed on Saturday, November 22nd at Midnight (central time). Get into the Christmas Spirit and join up in the Secret Santa fun by clicking on the link! Official FHC 2025 Secret Santa Gift Exchange
Square filing chains
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 17, 2014.
  1. Hedgerow
    Hedgerow
    SW Missouri
    Good...
    Now square file it out till the cutting side of the tooth looks like it's standing straight up...
    94BULLITT likes this.
  2. Hedgerow
    Hedgerow
    SW Missouri
    Top and side..
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    I will clean the rest then. It is still a factory grind.
  4. SquareFile
    SquareFile
    somewhere
    I thought so.... forward lean and not much angle under the top plate. File will take care of that.
  5. 94BULLITT
    94BULLITT
    Take a square file to the gullet?
  6. SquareFile
    SquareFile
    somewhere
    I'm not trying to speak for Hedgerow, but what he is referring to is the cutting edge. Try to keep zero lean of the side plate (straight up). The side plate is the cutting area above your gullet.
  7. mdavlee
    mdavlee
    2-3° is about right for lean on the side plate. More than that will get aggressive and pull real hard. 0 won't pull as hard but take more raker to bite good.
  8. 94BULLITT
    94BULLITT
    Okay, so he was saying to file the top and side back so that it is even with where the gullet material was removed?
  9. SquareFile
    SquareFile
    somewhere
    Talking cutting angles....you will need to hold the bevel file to get the angles you want.
    Skippy, mdavlee and 94BULLITT like this.
  10. Hedgerow
    Hedgerow
    SW Missouri
    Bingo... Just file till you have a good corner established..
    Don't remove any more tooth than you need to get that done.. Save that steel for future filings...
    Skippy, Oliver1655, DexterDay and 2 others like this.
  11. trx250r180
    trx250r180
    I am going to learn how to sharpen round
    Skippy, Hedgerow, Oliver1655 and 4 others like this.
  12. Moparmyway
    Moparmyway
    New York
    Its too hard, youll NEVER get the hang of it !!!
  13. mdavlee
    mdavlee
    I have a harder time making round not too aggressive now.
    Skippy, trx250r180 and Moparmyway like this.
  14. Hedgerow
    Hedgerow
    SW Missouri
    I ruined another file...
    Gotta order more..
    Down to 1 decent one, and a ragged out one..
    Skippy and mdavlee like this.
  15. 94BULLITT
    94BULLITT
    I finally got all of the gullets cleaned out on my chain. I've had project that has been real time consuming and I am still not done so I had not had much chance to mess with this chain. I took the saw out and it cuts a hair better. My next step is to square file it like hedge said.
  16. Oliver1655
    Oliver1655
    Central Missouri
    Survived Hedgefest. The results from the chain race were surprising & left me with several questions.
    First chain race definition as done at Hedgefest:
    - All chains were run on the same saw ( Husqvarna 562 Tlandrum modified), cant (13-1/2"), & by same operator - Hedgerow.
    - Chains were 3/8" drive, 84 links & most were .050 gauge. A couple were .063.
    - A test to see if the chain would bore cut as well as a single down cut timed with 2 stop watches was done.
    Unfortunately the chain I had sharpened for the race even though the box said was 84 DL ended up being only 82 so I will have to save it for another time.
    There were 2 factory Stihl chains run for a reference. Both were full chisel, one square ground & one round.
    Of the approximately 20 chains ran, only 2 were faster than the factory, Hedgerow & Mdavlee.
    Now the questions, why did the factory sharpened chains beat most of the hand sharpened chains?
    - Were they too aggressively sharpened to where if on an 80 or 90cc saw they would have shined?
    - Number of teeth, would less teeth (semi-skip or full skip) have worked better with the saw being used?
    - What about the size of the cant used? A smaller cant may have been better for the aggressively sharpened chains.
    It would be interesting in the future to test each chain on two different sized saws (maybe 65-70cc & a 90-95cc saw) & maybe 3 different sized cants (6, 10, & 14").
    Alright folks, lets hear some theories.
  17. 94BULLITT
    94BULLITT
    How much faster was the out of the box square than the out of the box round?
  18. mdavlee
    mdavlee
    I think the chains were mostly too aggressive. It's easy to go a little too far on them and make them hard to keep in a sweet spot on smaller saws.
    Skippy likes this.
  19. mdavlee
    mdavlee
    Here's the results sheet.
  20. 94BULLITT
    94BULLITT
    When I tested the square vs the round on the 034 super I got the same results, the square was .8 or .9 faster.
